4age bigport head: port & polish
11-14-2006, 02:48 PM
Post: #41
I would not be tempted to follow the N2 specifications, they are out dated and old theory. On the bigport heads i high advise NOT touching the port dimentions at the mouth of the port, it is already too large by a long way. Concentrate on the area from the valve seat to 0.5" infront of the valve guide..........THIS is where you will gain all your flow, anywhere infront of that will make no difference.
If you want to make them smaller then you will have to experiement with liquid aluminium since welding like i do is a very very expensive thing to do, there are many parts to do before you can use a head that has been welded. But also, you will have to spend alot of time on the flow bench and on the dyno to test the effects of making a port smaller. My advice would be to leave the port dimentions alone, you will see no gains by trying to make things smaller or bigger..........you will only cause yourself trouble in the long run. And because you are running ITB's, you can run much wilder cam, i would be looking at 275-280 at least or you will be wasting the RPM potential of the 4age. For the savenging, its all about exhuast header design. This depends on the head flow rates, valve sizes, port lengths and dimentions, cam specs aswell as installed cam timing, compression ratios, induction methods etc. Then you can calculate the exhaust header primarcy and secondary lengths, bore sizes, stepdowns etc etc. It is complex to get right, so most people will settle for a design that will work nicely, rather than perfectly. I would buy one of the already available manifolds unless you have £600-1000 to play with for headers. Do not run a cat, run a de-cat pipe. Os7213 Wrote:Haha nice thank alot! |
11-14-2006, 08:24 PM
Post: #42
Thank a lot for all you advises everyones!
BenR im now on the porting of my blue-top head(Since i have a blue-top for tests and a red-top to run the setup). What im gonna do its a porting match for the mounth of the port and ill do nice ports from the valve seat to the valve guide and reshape the splitter. That gonna be my test and ill post up some pics of the work! For the cams 272deg 9mm that i already have i think they could work pretty well with the red-top head ive chosse them for a nice and smooth powerband following the stock one but at higher rpms...And since i dont have money to spend on others cams ill keep them! But yeah the 280deg 9mm lift are very interessting. The idea of putting a 264deg cam was only to push the limit of the powerband to higher rpm but i really want to keep my middle power! And for the cat pipe ill take you advise and put it on dyno to compare! Thank Ugo |
11-14-2006, 11:00 PM
Post: #43
No problem.
Remember, port matching isnt everything. If the manifold is smaller than the port onthe inlet side, then its typically fine, it doesnt have to be a perfect match as too big.....as they say.....is too big. Have fun |
11-18-2006, 09:33 AM
Post: #44
Hi guys just to continue the thread and for more advise during the job i post some pics of some parts during the work. Today i have complete the shape and ill post pics when the finish will be okay. Oh almost forgot just for info someone told me to use a 400 grade sandpaper for the finish but im affraid that become too shinny someone have an advise?
![]() ![]() ![]() ![]() Note these pics are during the work but I think the final result is pretty good Ill post pics in no time but since its my first porting job please be smart guys ![]() Thank Ugo |
11-20-2006, 03:13 AM
Post: #45
The basics are looking good! you will notice a difference there, just make sure it had a good valve job now.
80 grit finish is all you need......400 is a waste of time. |
11-20-2006, 07:21 AM
Post: #46
Hi guys.
Thank for the advises BenR Here the final result of the shape before the finish: ![]() ![]() ![]() Oh btw if the port doesn't look simetrical i think its the finish who give this effect! So if i use a 80 grid paper everything sould be ok!I was affraid of a too shinny finish. Nice The valves should arrive soon and Ill make a 3angles valves job. Now i just need to do the 3 others inlets ports and the exhaust one ![]() Thank a lot Ugo |
11-20-2006, 04:52 PM
Post: #47
oh, you've gone too far........it was better in the first set of pics.
The ports are nor meant to be symmetrical. 80 grit is all you need. |
11-20-2006, 05:55 PM
Post: #48
Ah! unfortunately I have made a mistake but now i see the error!
I was trying to put the deck height more low and leave room for air but i hope that gonna be okay. I will not repeat the mistake! Thank Ugo |
11-20-2006, 11:27 PM
Post: #49
the deck height?
The first pic sets had a nice shape and not too much done..........remember, a good flow specialist gains maximum flow with minimum material removal. |
11-21-2006, 04:53 AM
Post: #50
Yes im sorry ive call it a deck since im not very good in english i mean the entry just before the 2 ports is too low! I now see the error like a 45ft truck hitting me... That was my second question is it true you only need small material removing lol Yes cause the new ports ive made take me almost no time to do and i clearly see the difference now
![]() Im not sure ill be able to use the head with a port like that.. but that what it cost to learn! Btw is this normal sometimes the valves seat are already bigger than the head..i mean to match them up cause on 2 valves seat on the head i cant remove any material to match up cause some material miss near the valve seat and create a little gap... But anyway ill just learn with this one, just for fun prepare it like this, blot it on the engine and see what it does! Because im really not sure i can use a port like this. For this one i have made a test from a Honda engine who have like i did big open ports with the bottom of the ports very low...since i know nothing and need to experiement its my first try but today i have work on the second port and i now understand! When i will finish ill send you a pic to show if i understand the thing! Thank a lot Ugo |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,208 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,643 |
10.8:1, 264/256° Bigport | nyberrg | 4 | 6,472 |
06-12-2017 09:57 AM Last Post: nyberrg |
Small Port Swap | Alex170984 | 1 | 4,253 |
11-21-2016 01:46 PM Last Post: Alex170984 |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,423 |
