4age camshaft CWC
07-29-2008, 04:34 AM
4age camshaft CWC
I currently have a set of cams for the 4age engine, the are supposed to be performance cams, the engravings on the cam are, cwc 271, e23. I was wondering if anyone has the idea of what cams are they and specs would be helpfull, and if it would work with stock ecu map
hello it is my first message from Guatemala I have ae86 levin I put photos to them of the car |
07-29-2008, 10:29 AM
4age camshaft CWC
CWC appears to be a manufacturer of cast camshaft blanks, that
they supply to various camshaft grinders for finishing. I have no idea which company ground your cams However, looking at the shape of the lobes it is likely that they are 304 duration cams. That sort of duration is usually associated with highly modified race engines, with poor idle and only making power above about 4500 rpm. They will not work well with your stock ECU. Depending on the lift, they may not work with standard valve springs or the stock shim over bucket lifters. Check the lift. If it is less than around 8.0 you could try running them. If it runs at all, the car will run like crap. Adding a piggyback controller may get it running a bit better. Best move would be to put them on the high shelf at the back of the garage until you build that "full race" motor you always dreamed about :wink: Cheers... jondee86 |
07-29-2008, 03:58 PM
4age camshaft CWC
thanks for its answer
my motor 4age 2 generacion trd piston camshft HKS head block worked and springs |
07-30-2008, 03:17 AM
4age camshaft CWC
And you are running this on the stock ECU... right ?
So how does it run ?? The stock ECU only has limited ability to adjust the fuel and ignition. Once the modifications to the engine go beyond the point where the stock ECU can keep up, performance and drivability will suffer. Big cams affect the engine vacuum, particularly at idle, to the point where the engine may not idle at all. They also change the amount of air entering the cylinders, so that the engine may run dangerously lean at high rpm, and ridiculously rich at low rpm. A duration of 272 deg is usually considered to be at the limit of the stock ECU. Raising the compression, porting the head and installing a free-flowing exhaust, will allow you to take advantage of the improved breathing of big cams. But until you get control of the fuel and ignition maps with an after-market ECU, you will never obtain the full benefit of your modifications. Cheers... jondee86 |
08-12-2008, 06:10 AM
4age camshaft CWC
If they are 271 lift then you should be okay. You need to measure the lift.
Question about camshaft | CHACAMAN | 2 | 3,681 |
07-07-2020 06:41 PM Last Post: oldeskewltoy |
Camshaft ID | kazi | 6 | 7,622 |
09-26-2018 12:07 AM Last Post: oldeskewltoy |
Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 16,000 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
Camshaft sprocket bolt size? | harkes | 1 | 4,662 |
Camshaft questions | d3nso | 7 | 8,088 |
08-16-2013 11:19 PM Last Post: jondee86 |
