4age stock bigport on turbo
01-16-2014, 01:14 PM
Hi there, I have a almost stock 4age bigport bluetop with AFM originaly bought in Switzeland but with no cat. Engine is stock but 4-2-1 exhaust manifold and under axle silincer system. It has egr removed and HKS fcon + HKS gcc controller piggyback ecu.
THis ecu is mainly fot turbo and SC aplications from I know.
I would like to know how much turbo press is safe and reliable to run with an engine on this spec and on OE gearbox and axle.
Would be a better option a SC route?
I have a brand new IHI turbo sitting arround and I guess it would be cheaper for me the turbo way.
I dont expect a huge amount of power, just a little more torque and few bhp to have more fun on track.
I run 185 on the rear.
Thanks in advance, Cheers
01-16-2014, 01:30 PM
The hks supercharger kit for 4age ran something of 6/8 psi i believe on a stock 4age but its hard to find info on it.
if you can read japanese here is the brochure
[Image: AEU86 AE86 - 4age stock bigport on turbo]
You could also swap in pistons from a 4agze or to source,excellent beginning for turbo or supercharger route Smile
01-16-2014, 02:18 PM
Thanks for the info mate, unfortunatly i cant read japanesse. I was planning on a add-on items without change internals. Maybe on the future i will rebouild the complete engine.
Cheers
01-16-2014, 02:31 PM
np Smile
I actually have the same idea of higher compression with low boost.
The hks kit would be perfect for you but they are so rare.
6-8 psi is a safe number then i think,im trying to find the exact number the supercharger kit ran but its hard if you cant read japanese.
01-16-2014, 05:08 PM
Sure it is hard!
I was planning on a eaton m45 from a mini or a mercedes with the mini mechanical bypass valve, but this SC is allways a bit more expensive than i want to invest and I cant find one on my local scrapy (they only sell complete engine)
So due to I have a new turbo behind the bed i was thinking on this route.
Cheers
01-16-2014, 06:57 PM
yeah tbh i wouldnt go the m45 route,will be buckets of money.
If you are a supercharger fan like me id suggest finding a 4agze and going from there,but it still wont be cheap.
if you manage things with that ecu the cheapest will be a small turbo with low boost i think on youre current setup
01-16-2014, 10:52 PM
Thanks mate, cheers
01-17-2014, 12:41 AM
i have an ae86 4ac. i bought a brand new 4age blue top big port engine and installed turbo.stock engine stock internal. now its going @1 bar with garret 28-71
i have a microsquirt standalone ecu. 550 cc rc injectors. intercooler etc.
here are videos
0-400 meter 14.8 with an open diff
http://www.youtube.com/watch?v=d3fdr2wrc5Y
and accelaration
http://www.youtube.com/watch?v=Ml0bIG5m-6E
01-17-2014, 01:02 PM
Yummie! Yummie!
Man thats what im talking about. Are you using stock gearbox and rear axle?
Cheers
  Digital speedometer on stock dashboard FanIsHere 0 1,428 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,858 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,561 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,655 03-24-2019 04:10 PM
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,522 04-20-2018 09:14 AM
