4agze ae86 wiring.
11-05-2012, 07:58 PM
4agze ae86 wiring.
Hi guys, I've fitted a GZE into my ae86. And I'm stuck with wiring. Mainly because, my GZE wiring has its own starter/ alternator loom in with the engine loom, and the ae86 starter/alternator looms are on the car.
I'm going to use the one already on the car, and cut mine out , but I need to connect this inside the car for it to work.
The colours I have to connect are these,
AE86 14 pin connector.../....GZE ECU connector
Batt live, red,white trace ...../.... Red,white trace
Ign live, black,red trace..../.... Black/red trace
Fuel pump trigger, green,red trace..../.... Green,red trace
Speed signal, blue,white trace..../.... Purple,white
In my GZE loom I have a thick black for a starter signal, but where do I connect this to?
Basically I need the wire colours to get this cranking.. Not just the ones to run the ECU.
I don't know what this pale yellow connector does in my ae86 , on the left of the picture.
[Image: AEU86 AE86 - 4agze ae86 wiring.]
Cheers
11-05-2012, 08:44 PM
4agze ae86 wiring.
http://forums.club4ag.com/zerothread?id=90711
scroll to the bottom,there is a wiring guide there Smile
11-05-2012, 09:26 PM
4agze ae86 wiring.
It doesn't mention the starter wires... But I'll connect those up and see how I get on.. Cheers
11-05-2012, 09:59 PM
4agze ae86 wiring.
I did look that long time ago and i think there show all you need to make wiring harness
  Tail light wiring... Mylesmck 4 1,126 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 4,659 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 7,107 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 5,599 05-18-2019 01:50 PM
Last Post: DJexor
  AE86 Headlight + wiper wiring (levin) bozu 11 16,270 09-19-2017 02:06 PM
