4agze timing
04-07-2017, 12:25 AM
4agze timing
Maybe you are right. I will make a last try with a set of peugeot 306gti cops i have on a box...it has 2 wires and it seems it can work.
Ive just wanna make a bit tidy engine bay plus with ic on top of head, plug wires are a bit of mess.
Thanks for all the info
Cheers
04-07-2017, 03:10 AM
4agze timing
Post a reply if you have success with this Smile The 2-wire COP's are just small coils
sitting on top of the plug. I think if you wire them in pairs as you originally suggested,
they should work. If the GZE igniter can switch larger GZE coilpacks to ground, it
should not have any trouble switching two COP's. The GZE igniter will supply the IGf
signal for the ECU.
Cheers... jondee86
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,136 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,417 11-05-2016 01:34 AM
  [Tutorial Video] Setting 4A-GE Ignition Timing Homem Bomba 0 5,686 04-21-2014 02:41 PM
Last Post: Homem Bomba
  Broken 20v upper timing belt cover chip 2 4,400 07-16-2012 07:11 AM
Last Post: Jan Pedersen
  4AC timing StarTrekAdmiral 4 10,027 04-13-2012 04:49 PM
Last Post: StarTrekAdmiral
