7 rib block for a bluetop head?
11-03-2014, 09:25 PM
JuSt picked up a old blue top and it has a decent amount of rust on the outside of the block. I'm sure I could Cleanot it off and buff amount way the rust but I just got a 7 rib shor block for $30 and dint know if I could put my bluetop head on it.
Thanks in advance, Dinkers |
11-03-2014, 09:54 PM
is it from a regular 16v? then yes you can use it
11-03-2014, 10:05 PM
(This post was last modified: 11-03-2014 10:06 PM by dinkers542.)
Man you are the single most helpful single perror I have ever encounters on a forum ever and I have been a member of quite a few!
It is a regular 16v head. Thanks, Dinkers |
11-03-2014, 10:39 PM
Its the block i mean, as long as its not from an ae92 gti from 90-92(smallport) or a second or third 4agze version they will fit no problem. Technically those fit as well but there is an external oil drain |
11-04-2014, 01:18 AM
Sorry for the mini hijack, but will a 20v Head fit on a standard 16v bottom end? :S
11-04-2014, 08:37 AM
(This post was last modified: 11-04-2014 08:38 AM by ditn.)
As far as i know it will not 100% sure
What happened? |
11-04-2014, 11:41 AM
(This post was last modified: 11-04-2014 11:46 AM by mad.matt.)
(11-04-2014 08:37 AM)ditn Wrote: As far as i know it will not 100% sure Spun conrod bearing no 2 Don't have the funds for now to do a full rebuild the way I'd like to, so was going to put the 20v block aside and buy a spare head and build it properly while I had a temporary 20v Head/16 Block in the corolla to keep me mobile. So sounds like I'll need to find a crank, rod and bearing set for now |
11-04-2014, 01:44 PM
(This post was last modified: 11-04-2014 01:47 PM by zenki.)
My 4age is a 7ribs with bigport head and tvis, works 100%. I had a 7ribs smallport in my old 86 and i remember that that car felt faster.
ハチロク |
Wanted: 3-rib engine repair manual | Ivan141 | 6 | 2,437 |
09-09-2022 07:46 PM Last Post: oldeskewltoy |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,619 |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 9,200 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,996 |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 86,923 |
05-05-2019 04:03 AM Last Post: Rocker100 |
