7agze oil pressure
07-04-2008, 10:43 PM
7agze oil pressure
Recently built 7agze with sc14 on 10w40 oil
Was concerned about oil pressure, fitted capillary guage. Read 28psi on warm idle with clutch in 40-50 psi on normal driving 63 psi max on throttle. Does this sound ok? Guage is in PSI Please help Listen to the whine. Not just a carbon copy. |
07-06-2008, 02:39 AM
7agze oil pressure
Not sure.
07-18-2008, 12:17 AM
7agze oil pressure
Considering the thickness of the oil you are using i would say the psi you have listed are fine.
Perhaps a little low but definately within limits. When WOT oil pressure gets around 40-50 then you need to dig deeper because something isnt right. Personelly for a boosted engine i would look at using 10-50 oil. Steve.....this is sparrrrrtan |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,725 |
Oil Pressure Query | Alex170984 | 2 | 5,363 |
12-11-2014 01:25 AM Last Post: Alex170984 |
trans oil, lsd oil change | Apolan | 9 | 17,595 |
Pressure gathering in fuel tank | Apolan | 9 | 15,461 |
05-18-2014 06:18 AM Last Post: chenfon |
oil pressure high | kawo | 17 | 21,137 |
09-29-2013 12:06 PM Last Post: allencr |
