trans oil, lsd oil change
06-03-2005, 08:30 AM
how do i change the oil in the transmission and lsd? where do i let it out and where do i refill?
PS: what swich controls the rear lights (for reverse)?
tnx for answers.
06-03-2005, 09:07 AM
There are 2 bolts on the rear axle, the bottom one is the drain plug, the one at the rear centre of the ax;e is the filler plug...just drain the fluid first, if it's nice and clean just fill it up until the oil is level with the filler hole (read: until it starts coming back out..). The gearbox works similarly.
But I must say, dont take our word for it, look it up in the factory manuals. We didnt put them on the site for nothing you know :wink: .
The reverse switch is somewhere on the side of the gearbox I think...havent really looked at it before but mine is broken so I will have to soon.
06-03-2005, 09:19 AM
so i dont have to take the transmission off to change the oil?
06-03-2005, 10:01 AM
Apolan Wrote:so i dont have to take the transmission off to change the oil?
No.
You can change it on car - just go to the oil change station or garage - this is not big deal man Cool
06-03-2005, 11:12 AM
Changing the gearbox oil is similar to the lsd, drain and filler hole.
[Image: AEU86 AE86 - trans oil, lsd oil change]
06-04-2005, 12:22 PM
changed the trans oil yesterday.. its a real beach ( :wink: ) to unscrew the fill-in hole.. anywayz it drank some 1.6 litres. the specs say 1.7, i guess its allright..
i also bought the LSD oil castrol hypol LS 90 or something like that. is that alright?
06-06-2005, 03:30 PM
Apolan Wrote:changed the trans oil yesterday.. its a real beach ( :wink: ) to unscrew the fill-in hole.. anywayz it drank some 1.6 litres. the specs say 1.7, i guess its allright..
Yes, It's allright man :-)
Expect 1.3 litres in the rear end.
06-10-2005, 06:01 AM
You might want to open up the fill plug before you open the drainplug. Nothing sucks more than opening up the drainplug, only to find the fill plug stuck on really bad.
To fill the transmission without using a pump, you can take out the shifter and pour in 1.7L through the shifter hole. I usually slightly overfill by putting in 2 quarts of MTL or MT90 (1.9L won't hurt anything, and helps assure lubrication of the input bearing)
HTH.
06-13-2005, 11:35 PM
What size is the bolt (fill and drain) for the transmission?
Is it 22mm?
Thanks guys
Trueno for sale!
10-01-2014, 03:57 PM
Quick note worth mentioning....make sure, with diff/gearbox, you can remove top nut first...
Otherwise you'll have no oil and no way of trying to refill it!
  Oil cooler -> low oil pressure Jan Pedersen 24 37,542 06-06-2013 07:36 PM
Last Post: Deuce Cam
  Change the meter between zenki and kouki T_AE86 9 13,821 12-03-2012 03:13 PM
Last Post: T_AE86
  More positive gear change phill 92 12 15,770 05-21-2012 10:51 PM
Last Post: phill 92
  LSD Oil, Necessary? phill 92 6 10,539 04-06-2012 05:17 PM
Last Post: Sgonzalez
  what clutch for a W58 trans to a 4AGE Blacktop? slowboy2 17 29,873 11-17-2011 08:36 PM
Last Post: slowboy2
