More positive gear change
03-28-2012, 02:21 PM
Hello,
I just done a quick look into short shift kits for my 86 as I'm Craving a more positive gear change with less travel (mine isn't too bad but my Daily has a short shift kit!) and I could only find the Ridiculous £130 TRD Kit. I don't have the money to spend £130 on a short shift kit and was wondering what cheaper options are around, what your using and what you think of it. Cheers. |
03-28-2012, 10:30 PM
Techno toy tuning does them as well, but it´s not much cheaper.
Or you go for diy... http://www.aeu86.org/index/gearbox-diy-s...post=58130 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-09-2012, 03:50 PM
I was really hoping for a cheap fix, wish I had the tools to go DIY!
Anyone used the Cusco collar shift or heard anything about them? |
04-09-2012, 07:29 PM
On a 2nd thought, do you have loads of slack?
This would just be the shifter bushing, the oem plastic ain´t that strong, especially after 25 years. You can get them uprated from Techno toy tuning for under 10quid and they make loads of difference. The Cusco does the same and ist made from brass, that´s why it costs 25 quid. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-09-2012, 10:46 PM
Yer thats my problem, I can put it into gear and it still has a load of slack its not bad its just a bit annoying!
Would it be possible to send a link? I'm defiantly interested in doing this myself, is it a relatively simple job? Cheers! |
04-09-2012, 11:04 PM
I made the shifter bushings myself on my lathe. Simple job and a big difference.
![]() AE86 Full Hybrid - Burns rubber and gasoline |
04-10-2012, 10:53 AM
https://technotoytuning.com/toyota/ae86/...86-corolla
The really important bit is the small bushing in the middle, chaning these bushings is very easy and takes maybe an hour? A while ago you could just buy the small bushing without the rest for 12USD iirc. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-11-2012, 01:24 PM
A new plastic bit from Toyota?
It'll last another 20+ years! So what! |
04-12-2012, 02:51 AM
allencr Wrote:A new plastic bit from Toyota? It is just as expensive as the T3 one... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-12-2012, 09:55 AM
Yer I don't fancy getting raped by Toyota! I think I might buy the techno toy tuning one tonight.
5th gear issue | r.ave | 1 | 2,719 |
03-14-2021 08:52 PM Last Post: Ivan141 |
ring gear bolts | DJexor | 3 | 5,646 |
12-26-2016 10:56 PM Last Post: totta Crolla |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,858 |
11-27-2015 10:06 AM Last Post: Project D |
Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 5,747 |
11-29-2014 12:27 AM Last Post: dinkers542 |
trans oil, lsd oil change | Apolan | 9 | 17,512 |
