Decently heavy vibration in fourth gear between 2000-2300rpm
11-28-2014, 12:55 AM
During acceleration between 2000 and 23or 2400rpm in fourth gear it feels like my tranny or enging are vibrating or shaking a bit. Any insight to what this might be?
Thanks,
Dinkers
11-28-2014, 08:13 AM
we'll need a bit more info. Is this under heavy load (i.e going uphill) or even when coasting (i.e. small throttle input)... also only in fourth gear or also in 5th and 3rd?
11-28-2014, 10:43 AM
More so under pressure but also when at low throttle. Gears 1-3 seem to be good and so does fifth but I will have to feel out fifth on my way to work.
Thanks,
Dinkers
11-28-2014, 12:01 PM
one thing you might want to check is the center bearing of the driveshaft... it's a long shot but might be the culprit.
11-29-2014, 12:27 AM
So I did notice it in 5th gear today on my way to work. I wish it wasnt raining cats and dogs over here I Seattle or I would get it up on stands to check today.
Although I hope it is the drive shaft as im getting all my gts swap parts on Sunday.
  No idle below 2000 rpm rich running Steller Engineering 3 1,728 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  5th gear issue r.ave 1 2,768 03-14-2021 08:52 PM
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,292 07-31-2019 11:28 AM
  ring gear bolts DJexor 3 5,691 12-26-2016 10:56 PM
Last Post: totta Crolla
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 6,924 11-27-2015 10:06 AM
Last Post: Project D
