Decently heavy vibration in fourth gear between 2000-2300rpm
11-28-2014, 12:55 AM
During acceleration between 2000 and 23or 2400rpm in fourth gear it feels like my tranny or enging are vibrating or shaking a bit. Any insight to what this might be?
Thanks, Dinkers |
11-28-2014, 08:13 AM
we'll need a bit more info. Is this under heavy load (i.e going uphill) or even when coasting (i.e. small throttle input)... also only in fourth gear or also in 5th and 3rd?
AE86 ex-daily |
11-28-2014, 10:43 AM
More so under pressure but also when at low throttle. Gears 1-3 seem to be good and so does fifth but I will have to feel out fifth on my way to work.
Thanks, Dinkers |
11-28-2014, 12:01 PM
one thing you might want to check is the center bearing of the driveshaft... it's a long shot but might be the culprit.
AE86 ex-daily |
11-29-2014, 12:27 AM
So I did notice it in 5th gear today on my way to work. I wish it wasnt raining cats and dogs over here I Seattle or I would get it up on stands to check today.
Although I hope it is the drive shaft as im getting all my gts swap parts on Sunday. |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,491 |
5th gear issue | r.ave | 1 | 2,595 |
03-14-2021 08:52 PM Last Post: Ivan141 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,802 |
ring gear bolts | DJexor | 3 | 5,433 |
12-26-2016 10:56 PM Last Post: totta Crolla |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,672 |
11-27-2015 10:06 AM Last Post: Project D |
