7agze oil pressure
07-04-2008, 10:43 PM
7agze oil pressure
Recently built 7agze with sc14 on 10w40 oil
Was concerned about oil pressure, fitted capillary guage.
Read 28psi on warm idle with clutch in
40-50 psi on normal driving
63 psi max on throttle.
Does this sound ok?
Guage is in PSI
Please help
Listen to the whine.
Not just a carbon copy.
07-06-2008, 02:39 AM
7agze oil pressure
Not sure.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
07-18-2008, 12:17 AM
7agze oil pressure
Considering the thickness of the oil you are using i would say the psi you have listed are fine.
Perhaps a little low but definately within limits.
When WOT oil pressure gets around 40-50 then you need to dig deeper because something isnt right.
Personelly for a boosted engine i would look at using 10-50 oil.
Steve.....this is sparrrrrtan
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 20,993 08-19-2018 12:08 PM
Last Post: AlexKTM
  Oil Pressure Query Alex170984 2 5,148 12-11-2014 01:25 AM
Last Post: Alex170984
  trans oil, lsd oil change Apolan 9 17,059 10-01-2014 03:57 PM
  Pressure gathering in fuel tank Apolan 9 14,883 05-18-2014 06:18 AM
Last Post: chenfon
  oil pressure high kawo 17 20,375 09-29-2013 12:06 PM
Last Post: allencr
