'84 ae86 restoration project
04-21-2014, 10:18 PM
Keep us update Randy!
![]() 1985 AE86 (ハチロク) Levin - Summer time daily driver |
04-21-2014, 11:11 PM
I'll do my best, have some cool bits laying around that are going on, still have some ps knucles, battleversion steering kit and some other bits. Only need to find some original seat belts as they are not in the car because the rollcage was in the way, but I need them for technical inspection only...
No Smorking AE86 |
05-11-2014, 08:23 PM
Unfortunately while stripping the car I kept finding more and more rust, so I won't be using the ae86 shell. I'll be transferring all the parts to this thing...
![]() It is a 1986 Daihatsu Charmant 1.6le Has a 4a engine, t50 box, and only 80000km. I bought it from the first owner who was 85years old. I'll be putting the ae86 shell and all parts up for sale after I have pics of it all. If you need anything let me know ![]() No Smorking AE86 |
05-11-2014, 09:46 PM
I want the rear caliper Randy!
05-11-2014, 09:52 PM
... how bad can it be ?
05-11-2014, 10:40 PM
I think I know how bad it can be...
Sent from my HTC Desire HD using tapatalk FABRICA MI DIEM, PVNC! |
05-12-2014, 05:45 PM
It's pretty bad, entire right side from passanger side footwell to b pillar is gone. Seat mounts are not attached to the car anymore...
Everything was covered up, so didn't see it till it stripped everything down. Going to make a list of parts in the for sale section in a few minutes, have a lot of parts that can go ![]() No Smorking AE86 |
05-12-2014, 08:46 PM
Auch! :shock:
Charmants are cool btw! The engine+tranny of my old ae86 were swapped into one and it was able to do charming donuts afterwards. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
05-12-2014, 10:08 PM
First I'll swap over the suspension bits, engine will be later on after i've overhauled it, must remain daily driveable.
No Smorking AE86 |
10-13-2014, 09:20 PM
(This post was last modified: 10-13-2014 09:23 PM by HybriD07.)
Small update:
Rebuild the engine, swapped over everything in the Daihatsu. Engine spec r1carbs DanSt Engineering intake manifold 272° cams ported head raised compression new valvetrain cleaned bottomend new pistons rings bearing ... Got it running, now just sorting out the ignition parts to work as it should. Almost ready. No Smorking AE86 |
Full restoration... | Blade1988 | 64 | 86,032 |
07-17-2016 11:53 AM Last Post: McGlinchey |
Another danish restoration | Duze | 61 | 72,950 |
03-20-2016 08:58 AM Last Post: Duze |
TOYOTA COROLLA Ke70 - Restoration project | cke70 | 34 | 51,619 |
07-02-2014 10:12 PM Last Post: cke70 |
Black Limited restoration | slpery86 | 6 | 9,996 |
12-17-2013 09:22 PM Last Post: banpei |
A.D.D Performance AE86 RESTORATION NEARLY COMPLETE | cab32 | 24 | 30,402 |
08-08-2013 09:27 AM Last Post: Martynas |
