'84 ae86 restoration project
04-21-2014, 10:18 PM
Keep us update Randy! Thumbs up!
04-21-2014, 11:11 PM
I'll do my best, have some cool bits laying around that are going on, still have some ps knucles, battleversion steering kit and some other bits. Only need to find some original seat belts as they are not in the car because the rollcage was in the way, but I need them for technical inspection only...
No Smorking AE86
05-11-2014, 08:23 PM
Unfortunately while stripping the car I kept finding more and more rust, so I won't be using the ae86 shell. I'll be transferring all the parts to this thing...
[Image: AEU86 AE86 - '84 ae86 restoration project]
It is a 1986 Daihatsu Charmant 1.6le
Has a 4a engine, t50 box, and only 80000km. I bought it from the first owner who was 85years old.
I'll be putting the ae86 shell and all parts up for sale after I have pics of it all. If you need anything let me know Wink
No Smorking AE86
05-11-2014, 09:46 PM
I want the rear caliper Randy! Smile
05-11-2014, 09:52 PM
... how bad can it be ?
05-11-2014, 10:40 PM
I think I know how bad it can be...
Sent from my HTC Desire HD using tapatalk
05-12-2014, 05:45 PM
It's pretty bad, entire right side from passanger side footwell to b pillar is gone. Seat mounts are not attached to the car anymore...
Everything was covered up, so didn't see it till it stripped everything down.
Going to make a list of parts in the for sale section in a few minutes, have a lot of parts that can go Wink
No Smorking AE86
05-12-2014, 08:46 PM
Auch! :shock:
Charmants are cool btw! The engine+tranny of my old ae86 were swapped into one and it was able to do charming donuts afterwards. Wink
05-12-2014, 10:08 PM
First I'll swap over the suspension bits, engine will be later on after i've overhauled it, must remain daily driveable.
No Smorking AE86
10-13-2014, 09:20 PM (This post was last modified: 10-13-2014 09:23 PM by HybriD07.)
Small update:
Rebuild the engine, swapped over everything in the Daihatsu.
Engine spec
r1carbs
DanSt Engineering intake manifold
272° cams
ported head
raised compression
new valvetrain
cleaned bottomend
new pistons
rings
bearing
Got it running, now just sorting out the ignition parts to work as it should. Almost ready.
No Smorking AE86
  Full restoration... Blade1988 64 83,913 07-17-2016 11:53 AM
Last Post: McGlinchey
  Another danish restoration Duze 61 71,171 03-20-2016 08:58 AM
Last Post: Duze
  TOYOTA COROLLA Ke70 - Restoration project cke70 34 50,416 07-02-2014 10:12 PM
Last Post: cke70
  Black Limited restoration slpery86 6 9,811 12-17-2013 09:22 PM
  A.D.D Performance AE86 RESTORATION NEARLY COMPLETE cab32 24 29,677 08-08-2013 09:27 AM
Last Post: Martynas
