'85 2door from Belgium
07-26-2012, 11:08 AM
Post: #471
<=red ae86 yesterday
07-26-2012, 07:07 PM
Post: #472
Ah ok, have seen you around a few times before on trackdays.
No Smorking AE86 |
07-27-2012, 11:09 AM
Post: #473
yes i have done the skylimit trackdays a couple times now
![]() If only i would live a bit closer i could come more. |
07-27-2012, 03:23 PM
Post: #474
next time driftschool aswell?
![]() No Smorking AE86 |
07-29-2012, 03:07 PM
Post: #475
I would love to but there are alot of things i need to do first.
installing a w58/4AGZE probably and the slowly sideways rally restoration. Drifting is something i want to learn ![]() |
08-27-2012, 11:46 PM
Post: #476
Anyone notice something wrong in the next pic?
08-28-2012, 12:22 AM
Post: #477
do you put a s14 rear end?
SR Team BURN THE RUBER NOT YOUR SOUL! |
08-28-2012, 07:06 AM
Post: #478
Nope, e36 rear end. Subframe is much smaller and a lot easier to get in the right place.
No Smorking AE86 |
09-01-2012, 10:24 PM
Post: #479
Ok so a little update is on order.
Since the stock corolla rear axle couldn't handle the mega power of the stock 4age, it will crap it's pants with beemer powers. So having a complete m3 meant I could switch over the rear subframe from the bmw. Dimensions of the subframe are much smaller then s13/14 items, and better suited for the little corolla. ![]() So the bmw subframe and the space it will go in. ![]() Had to modify the camber arms, they took up a lot of room meaning I had to cut away too much. I won't be running bmw rear suspension. ![]() Then made a frame to weld to the bottom of the car, this is still undergoing strenghtening so no worries ![]() ![]() As you can see here, the ae suspension bolts on directly to the bmw subframe, no mods what so ever. ![]() That's when we rolled the car out the garage for the first time, still need to tweak some of the allignement, haven't got any pics of the toe-arms, but adapted them to fit to the corolla's lower control arm. No adjustment left, but we made them to have 0° toe, which always worked perfect on the corolla. ![]() Also the track of the m3 is 10cm wider as the corolla. Got some overfender to fit back, so not really worried about fitment. Only thing I'm worried about is lack of grip on the rear, so have some 10j wheels with 255 tires to try out ![]() Next update: Custom driveshaft Wiring Winning!!! No Smorking AE86 |
09-01-2012, 10:38 PM
Post: #480
Looks good. Can't wait to see it in action.
![]() ハチロク ![]() |
A Portuguese Hachiroku in Belgium (lots of pictures) | Lt86 | 25 | 21,825 |
04-05-2017 08:08 AM Last Post: Lt86 |
levin from Belgium - demee76 | demee76 | 46 | 61,946 |
08-28-2015 03:06 PM Last Post: demee76 |
Belgium project | Roger | 12 | 16,378 |
08-03-2015 08:46 PM Last Post: Roger |
belgium ae86 | boedtsie | 8 | 11,743 |
06-01-2015 05:25 PM Last Post: Lt86 |
ae 86 from Belgium [Brembo installed] | seb | 67 | 84,862 |
05-19-2013 07:52 AM Last Post: seb |
