86 Battery Problem?
12-13-2010, 08:00 AM
86 Battery Problem?
Best advice.... get the car to an auto electrician, and ask him to check
for parasitic current draw. A bad diode in the alternator rectifier is one quite common cause for "battery always flat" syndrome. Cheers... jondee86 |
12-13-2010, 05:39 PM
86 Battery Problem?
Earth problem maybe ?
Check especially the earth to the engine. An analogue brain in a digital World |
12-13-2010, 05:48 PM
86 Battery Problem?
Or just a tired starter motor.. or a combination of both.
If the starter has worn bushes it will only tick over at full charge..and then only when it feels like doing so. But easy to check the current over the battery with a multimeter. A wheel to steer the front of the car A pedal to steer the rear |
AE86 Battery specs | hachirokuGTV | 9 | 17,391 |
03-13-2020 04:16 PM Last Post: Power_uP |
Quick question for those who have relocated their battery.. | Jezza_hr | 10 | 11,538 |
03-06-2014 12:38 AM Last Post: rene |
Jap battery in uk? | phill 92 | 3 | 6,605 |
11-06-2012 11:00 AM Last Post: phill 92 |
battery question | Petros AE86 | 5 | 7,344 |
10-17-2012 08:15 PM Last Post: JGeorge |
4agZe problem solved - 99% IC problem | Okami | 41 | 37,718 |
07-12-2012 04:49 PM Last Post: Okami |
