86er's Track rebuild N2.??? Finally an update page 8
06-02-2011, 04:15 AM
Post: #171
good work on the body work..
06-24-2011, 05:50 AM
Post: #172
Ok so rewind
Ok so its been a while but still here, not sure where to start
some 2+years ago this car got parked and parted out after i had a weird fuel/ignition problem (was acting like it was running on 3cyls and would cut out after a while) which led to a second engine knock ( this was after driving car fine for 7+ months since the first knock becuz of sump pan) So that pushed me to halt project and I sold most of the nice bits and kept the shell.
[Image: AEU86 AE86 - 86er's Track rebuild N2.???...ate page 8]
Anyway enough of that so It was parked for a while some couple months just catching dust & rust when I decided that i was going racing. I always loved track cars, mostly for the builds and the engineering that would go into making a perfect weapon, and I always wanted to take a stab at making a perfect weapon, it wouldnt need to be too fast but i would need enough grunt and reliability was important, but handling and braking was key. So I painted i rough picture in my head, wasnt sure of everything, but I knew it could be done.
So I started rough planning and talks, I knew I wanted it to be as light as I could afford, so I started with a chromolly cage. At this stage I had to contemplate what to do about a serious rust problem that had manifested itself with my roof from the previous removal of sunroof. I cut it out
After the cage was done the project got parted again, for another year and some sadly, I guess I had gotten caught up with other stuff, but at the beginning of the year I made a push to get it back on track and on its way to completion.
There are a lot of ideas in this car and its not 100% where i want it its still a phase one build even at this satge, but here goes.
As far as power plant I considered alot of options in the last few months before the build restarted, mostly focused on reliable power (200-230hp), so looked at alot of stock 1800-2000cc 4cly, the altezza engine was a great match to car so it was high on list but it is heavier than say a sr20ve, k20a, f20c or some of other 2lts. I heavily considered the Ford Duratec 2.0 as i think its a gem of a engine, small, light weight 2lt capable of an easy 200bhp with little work and 300 with a lot. The thing that stopped me going that route was having to shop in pounds and euros, at the moment it was a bit too much of a deterrent. Anyway my choice was decided when I got an opportunity to get another beams swap complete, so I jumped at it.
Now the shell had gotten a bit rustier even though I tried to weather proof it in this time as best i could so was more work to be done. Now the first thing I had planned to do with the motor of choice was optimize balance and weight distribution, so this meant ultimately in the current configuration, a front mid mount, this was one of the more challenging bits of the build, so we tackled it first
It was a tight fit, alot of cutting, massaging, then came mounts
Will post more in morning, it continues to be long days/weeks/months
06-24-2011, 08:23 AM
Post: #173
This might just become an epic thread again. Subscribed.
08-04-2011, 07:05 PM
Post: #174
GOod work.. I remeber when i had to build my honda.. It wasn't eazy to deal with body work..
08-27-2011, 04:51 AM
Post: #175
still lots to be done but we made it to the track today did 2 test laps first impressions are good so far,86er got to update this thread
08-28-2011, 03:06 PM
Post: #176
All I can say is WOW! Really nice job man! Keep the good stuff going! Thumbs up!
Looks like a winner Cool
09-03-2011, 02:09 PM
Post: #177
lol Thanks to Kaiju been meaning to come and update been so tired and busy just trying to get the car running
So onward and forward, you are going to be seein this guy a lot he is the master fabricator that builds it all
Once we got her in we felt good but still tons to do
floating on stock sus,
at one point in time I was going to use the trueno front end which i had acquired minus a bumper, but I was influenced to stick with the levin front, the current aero package would be based on a CBY, with a little help from skyrider I was able to get a copy of his cby flares and he loaned me some wheels to fit up the front coilovers. We used ohlins from a DC5 with 86 spindles at bottom, once we worked out strut heights we pulled down the front shocks and did needed modifications to the cases
the steering works off top of strut in the dc5 and we kept that as the new engine location required relocating steering
car on ground well the front at relative height, still only had 2 wheels and rear coils were on as yet
Now the best part of the CBY kit for me was the front bumper, it always seemed to be one of the most functional bumpers for the 86 to me, one large opening for coolers to convenient ducts for cooling brakes and a nice front lip reminiscent of the trd n2 lip, also it keeps the lines of car, a nice starting point. So i had it made locally
\[Image: AEU86 AE86 - 86er's Track rebuild N2.???...ate page 8]
back on 13s for now, bumper on its way
its hard to move around in here
wow its low on 13s, but alot of work still top be done on rear suspension
intake acquired, 20v bt itbs with proper 50mm stacks
an idea of seating position with help from kaiju. The shiter now ends up back where handbrake normally is so this meaint moving back, I didnt mind it was all part of the plan, to help centralize weight distribution. Im kinda fleshing out details as we go along, no outright mod list at the beginning of this thread update.
The completed bumper
This front duct is a key part of aero/air flow package, more on that later
onto gearbox mounts
an an early look at a new crossmember
09-03-2011, 02:11 PM
Post: #178
So anyway gearbox in final position, these bushings would be changed to poly bushings for motor and box. More cutting for exhaust and the loaner seat in general location (alot of this build was based on borrowing in early stages while i orderd/waited for parts :o )
Onto the rear end
We are using a 6link rear end design. So 4 equal length arms and a watts link. The diff is a nissan Vanette with a 4.8 here are first stages, also arms are chromolly
We realized that rear was too high at this point so we said we would have to lower the shock position on rear diff later, that will come down the road.
Another 86 builder from a famous shop in St. George lent me some wheels with 3b rubber so I could see what stance and so was like
I was excited Blush Blush
Co-owner/builder looking over work
slapped on my old bonnet 8o
an idea of high rear this is with coilovers almost right down, this had to be rectified
a loaner spoiler from a honda lol
Parts started arriving and I got the front brakes minus hats,
Alcon monoblock calipers with some huge wilwood 2 piece rotors (11.75x1.25)
also some cusco bottom arms i acquired from japan completely replaces tension rod brackets with some nice pieces
was time to remove the old roof skin
new roof = lower CG Cool
09-03-2011, 02:12 PM
Post: #179
Cutting to make room for intake for itbs
sadly i didnt pics of this but here is the start of the tunnel, this piece was bent over the edge of a table by Mike :o
Welding in
Second part of tunnel made by mike as well
yeh my new whitelines are here, who says track cars cant be smexy
Also got the new Zenki grill
More tunnel work and some door chopping
Ok so Finally got some of other main bits
wheels
Radiator
Hat to complete brakes
Seat
Meanwhile the new bonnet was being worked on
and fitted up front rotors
09-03-2011, 02:14 PM
Post: #180
now you can get an idea of of front cooling design and what all that dead space is for
some old tank :roll:
i secured one complete tilton brake pedal with cylinders, now i just need 2 more pedals lol
No tires yet so, also the firt spoiler which I ended up selling, 3a spoiler rules suck Tongue
So Mike took a piece of corner section
then he took this sheet
cutting up an old sump
Someone lent me some old rubber, yes I am a bum lol
this man wont stop gettin in front my pics Angry
Progress with the new oil system
Oh shit bonnet is here more fitting up porn
Evo 4 rear brakes mounted
Oil tank mounted
Swirl pot arrived and some lines
Slacking off Tongue
this goes here
Time to lower rear shocks
Final steering design Fitted
radiator mounted
Oil cooler is here
Bought some rubber
more stuff came
  Scottish Trueno rebuild - Nürburgring with pics! kazi 77 195,804 11-25-2018 11:42 PM
Last Post: kazi
  86er Levin Hatch from Germany ArToAE86 19 17,366 01-24-2018 10:35 PM
Last Post: ArToAE86
  Patrick's rebuild topic PatrickAE86 13 20,195 11-22-2017 05:49 PM
Last Post: The Doctor
  DidiDex 1984 Levin coupe rebuild DidiDex 1 5,656 08-13-2015 03:22 PM
Last Post: DidiDex
  Track AE86 Build from south america Nurburgring 3 8,302 10-30-2013 07:31 PM
Last Post: BOOMEX
