88 toyota corolla all wheel trak wagon
08-16-2010, 06:55 PM
the engine wont turn over when it is warm, nor will the starter solenoid "click".
but when the car cools down for an hour it starts fine. Is this a sign of the starter solenoid going out or is this a relay problem somewhere?? I can push start the car(pop the clutch) and it runs fine. Its as if the start position on the ignition switch isn't working when its warm. Any suggestions on where i should look to fix this problem? |
08-16-2010, 07:03 PM
Had that in the past and simply changed the starter. Fixed the problem. You could try and see if you manually gie the starter power if it will turn over
08-16-2010, 07:35 PM
Ok thats what i was thinking - i just wanted to check in on it - i just bought the car and have never owned a toyota before which makes me not know the quirks. Besides this problem the car seems really solid and clean. Thanks for the reply
08-28-2010, 04:00 AM
Which engine is it? Is the starter under the exhaust manifold? Next time it happens try giving the starter a good whack with a hammer (not joking). It used to happen on my MR2, the starter overheats and somehow the hammer gets it going. You still need a new starter in the end but it should work for the meantime. It sucks having to do this in the rain
Something of interest to all suspension number crunchers | Bean | 1 | 4,512 |
01-05-2015 10:29 AM Last Post: Uzelac |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 9,005 |
10-30-2013 11:18 PM Last Post: banpei |
How to rebuild the AE86's brake system all around | Homem Bomba | 7 | 15,307 |
07-02-2013 10:31 PM Last Post: Homem Bomba |
All I should know about suspension before any modification | damusto | 20 | 24,117 |
05-24-2013 09:28 PM Last Post: damusto |
Daihatsu Charmant suspension same thru all years? | Allexz | 6 | 9,451 |
12-30-2010 09:27 PM Last Post: banpei |
