A/C idle up on my GZE
08-15-2011, 07:42 AM
Hi guys,
When I switch on my aircon the revs of my engine drops quite a bit (approx 200 to 300) and I feel a large power drop..
When during driving when the a/c circuit disengages the compressor I feel the engine becoming lighter and then when it comes on again there's a huge power loss..
I assume the power loss is normal but I didn't feel this much of powerloss while I had my 4AGE when the a/c comes on..
No one seems to know how the a/c idle up works in the GZE..
Does anyone know how this works?
CUrrently when the car is running without a/c it idles around 800 and then if turn on a/c it'll drop to like 600 or 700 at that low point.. But on a cold start the idle start around 1200 and if I turn on a/c it drop to around 800..
How can I fix this?
I was told that there a vacuum system that would put open the butterfly based on its setting.. Is this correct?
Cheated on my いたずらな女の子 and now I can't get enough of her..
08-15-2011, 08:17 PM
I know there should be a seperate vsv on the normal 4AGE for the aircon that will increase revs when engaged, so most probably such a switch is also available on the GZE.
Perhaps this topic can be of any help:
http://www.aeu86.org/viewtopic/vacuum-se...lp_/t/6761
[Image: AEU86 AE86 - A/C idle up on my GZE]
08-17-2011, 05:11 AM
You need to bear in mind that both the AC and SC runs with belts connected to the crank pulley so it could play a role on your idling and loss of power.
Current - 2006 Run X RSI TRD spec
Current - 1991 AE92 Conquest 4AGTE
Ex - 1992 AE92 Corolla 4AGTE(175KW&295NM)
Ex - 1983 1.8 SE Liftback(headworks and side draughts)
08-19-2011, 10:50 AM
Yes, I understand the power loss but I think if the engine could revv up then I think the power loss won't be felt this much..
I'll keep updated when the mechanic looks at this problem..
  No idle below 2000 rpm rich running Steller Engineering 3 2,795 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 11,374 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 9,649 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 6,500 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 12,398 10-16-2017 10:22 PM
