AE80
02-17-2006, 01:00 PM
AE80
I've got one of these, mine is actually an EE80 so with the 2E engine and automatic gearbox.
I think the engine swap should be relatively easy since you could swap everything with the parts of an AE82 GT hatchback (eventually including the fenders, grille and hood). I don't race cars so i don't know much about this but i think getting it balanced is hard as was said before in this topic. If I drive my car trough a corner fast it has terrible understeer. It'll probably be fun to do this but not very wise. At least I am not considering it... BTW The early model (<1985) 1.3 engines where 2A's so 8 valve engines, i think once the 1.3 was upgraded to 12 valves the 4A 8 valve SOHC engine was not available anymore. At least that's for the Netherlands. |
02-17-2006, 01:09 PM
AE80
Keep in mind that EE80 will not take direct A-series engine swap (just the engine without the tranny components).
02-17-2006, 01:16 PM
AE80
A 4E-FTE off of a starlet turbo should fit the EE80 though..
Using: -98 Camry 3.0 V6 Abusing : -85 Corolla 2.0 GTi |
02-17-2006, 01:33 PM
AE80
jamiemirror Wrote:Keep in mind that EE80 will not take direct A-series engine swap (just the engine without the tranny components). My car is an EE80 but the car described here is said to be an AE80 so with the 4A-l engine. Wouldn't that make things easier ? Off topic: I wonder how the automatic gearbox in my car would keep up when swapping to 4E-FTE... Not wise either I think |
02-17-2006, 01:42 PM
AE80
EE80Liftback Wrote:Off topic: I wonder how the automatic gearbox in my car would keep up when swapping to 4E-FTE... Not wise either I think Only one way to find out, right? No you're probably right. The added torque will probably fry the tranny. But if you get a front clip of the turbo starlet you get the gearbox too.. as well as everything else you need. Using: -98 Camry 3.0 V6 Abusing : -85 Corolla 2.0 GTi |
