AE85/3au wires - Which goes where?
12-23-2006, 01:13 AM
Just recently i have put a new 3au in my ae85 to get it past that new smoke restriction. Everything is in and complete except for three wires on the side of the engine. Three in one plug on the car side, and 2 different plugs on the engine side. I have no idea which wire does what and connects with which.
They are located on the passenger side of the engine, about halfway along the block behind the starter motor.
It may also be worth mentioning that the engine is not turning over, not a sound from the starter motor, but the stereo works fine Cool
[Image: AEU86 AE86 - AE85/3au wires - Which goes where?]
Current Cars:
'86 SE82 FX GT
'88 NZ New KE70 Van (Daily)
12-23-2006, 12:16 PM
Hmm..not too many of us familiar with the 3AU engine around here...it was never sold in hachi's in europe and the US.
The wiring cant be that difficult for the starter engine at least, and you could trace those loose connectors back to see what they are for (which would help).
The starter only needs one signal wire to work, and one big fat power cable.
You could try bridging a wire straight from the battery to the signal wire attachment to find out if the problem is in the starter or your wiring.
12-24-2006, 12:15 AM
Hmmm, i knew that most people here wouldn't know it, but it was worth a shot right?
I was going to try something along those lines, but i thought i'd ask around a few places, just incase someone could tell me.
Current Cars:
'86 SE82 FX GT
  Ignition switch plug and wires Blaze0010 3 1,182 11-25-2024 12:29 PM
Last Post: Blaze0010
  20v BT - which oil pump? Mylesmck 4 3,710 06-21-2022 04:51 PM
Last Post: pack
  Ae85 swap 4age. Minidaxman 8 6,711 04-07-2021 10:16 PM
Last Post: Minidaxman
  ae85 kickdown cable MIGGZFSU 0 3,448 05-04-2017 04:23 PM
Last Post: MIGGZFSU
  Rim width. Which is best.... Dino86 5 7,550 01-07-2017 03:09 PM
Last Post: Dino86
