AE85 Power! From 175HP 20v to 202HP F20
10-22-2011, 06:58 AM (This post was last modified: 07-06-2014 01:30 AM by 4000GT.)
Pictures say it all... 175WHP (more to come), fairly extensive shopping cart.
Before...
[Image: AEU86 AE86 - AE85 Power! From 175HP 20v to 202HP F20]
After...
10-22-2011, 07:51 AM
nice work mate!!
give us some specs. Hurray!
10-22-2011, 08:26 AM
you did a great work Wink
What are the spec of the engine?
SR Team
BURN THE RUBER NOT YOUR SOUL!
10-22-2011, 08:33 AM
Excellent, amazing looking 86
10-22-2011, 09:12 AM
Oh geez specs, this will be a write up!
Engine:
Custom header (SS 304 in 1.5" diameter primaries and 660mm long, to a full 2.5" SS 304 exhaust, DEI header wrap
Custom Aluminium intake with CNC backing plate with built in 45mm velocity stacks.
3SGTE injectors
Coil On Plug ignition
Sliver top block (I grenaded a Black Top one) with balanced crank, ARP Bolts throughout, ACL bearings, Tomei rods, custom CP pistons, 15:1 CR.
288 degree 10mm lift Kelford Cams
Supertech 1mm OS valves, Supertech Valve Springs
Excedy Lightweight Flywheel
Setrab oil cooler and TRD oil filter with HKS adapter off the block
Moroso catch can (shortened to meet regs) with K&N filter
Half size radiator with alloy shrouding and electric fan
K&N 3" cone filter
ARP alloy heat shield
TRD oil cap
TRD 0.8mm headgasket
Rest of drive train
T50 Gearbox
TRD Short shift
TRD 2 way LSD
Redline oils throughout
Braided clutch line
Wheels and brakes
15X8 +10 offset rims with Toyo R88 205/50 rubber
Wilwood Dynalight 4 pot brakes
Wilwood brake pads
Wilwood slotted and drilled rotors
SS brake lines
Nissan R33 brake booster
Momo pedals
Cusco brake booster stopper
Body
Fibreglass Front bumper, Bonnet, Front guards, Side Skirts, Rear hatch and Rear bumper
Lexan MR10 rear hatch and side window glassing
Racetech canvas toe hooks
Seam welded
Aerocatch bonnet pins
New rear updated tail lights
Plastic bolts used where possible
Interior
Flocked dash and door cards
Digital Dash conversion
Sabelt seats
Bride seat rail (passenger) and custom alloy for driver
Takata 6 point seat belts
Innovate oil pressure and engine temp gauges
Fuel pressure, oil pressure and water temp warning lights
Momo steering wheel and Momo quick release hub kit
T3 handbrake button
USI cage padding
Bride floor mats
TRD gear knob
TRD push start button
ECU and fueling
Vipec V44 custom looms (everything unnecessary removed)
RCI fuel cell with level sender
Custom surge tank and Bosch 910 pump
Mr Gasket lift pump
Suspension
TRD shocks (short stroke)
TRD springs (8kg front 6kg rear)
Whiteline sway bars front and rear
Tein camber plates
T3 adjustable panhard rod
T3 4 link adjustable rods
T3 castor rods
T3 Lower control arms
T3 manual rack nolethane bushes
175WHP running aviation fuel. Road registered Smile
Thats all I can think of off the top of my head!
10-22-2011, 09:13 AM
Eircamae86 Wrote:Excellent, amazing looking 86
Its an 85! Build to destroy 86's! mwahahahaha
10-22-2011, 09:57 AM
Nice, how much does she weigh?
10-22-2011, 10:06 AM
Hard to say, I would think around 850kg? I will have to get it weighed sometime. The main issue remaining is the factory metal doors, they weigh 26kg each, I can cut that to 6kg with fibreglass doors!
10-22-2011, 10:19 AM
Engine bay lack of wiring is very tasty
10-22-2011, 01:47 PM
Veery nice looking classic AE86! Amazing work.
I was always wondering why there are not more people with a propper airbox on there stacks. Heat soaking and such...
A airbox will always be better...
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
  Ae85 Minidaxman 4 5,328 04-20-2021 09:57 PM
  Sam's AE85 Conversion Sambo 2 17,047 05-20-2014 05:03 AM
Last Post: Sambo
  Stalkers daily AE85 - 7AGE stalker 32 54,029 12-28-2011 02:28 PM
Last Post: stalker
  Tofu's AE85 F20C Project Tofu 31 66,808 07-30-2011 10:58 PM
Last Post: kennedy8383
  Ricks project AE85 (Back together with dyno results) Rick 132 265,343 07-05-2011 11:54 AM
Last Post: Rick
