AE85 electrical diagramm
07-11-2008, 09:46 PM
Hello!
Maybe someone have or knows where to see\download AE85 electrical diagramm? AE86 is not compatible. Thanks! |
07-12-2008, 09:45 AM
damn i download the AE86 book manual
from a good source its scanned very good but i didnt have problems with th ewiring but didnt know arent compatible good tip man now i know if u have a AE85 like i do what engine u could have 3A or 4A just curious if u have a 3A-U please let me know i have a big probelm with the distributor vacum hoses that are disconected when i bought it |
07-12-2008, 09:48 AM
Yeap, I have 3A-U, and I don't know, can I help or not... But I'll try =)
07-13-2008, 06:04 AM
Hald Wrote:Yeap, I have 3A-U, and I don't know, can I help or not... But I'll try =) nice man have th esame engine and searching what 4age wll be the best option to fit i have an idea if u want please add me to ur msn my email is if u want add me to ur list to chat and help us with photos and i can help u too the distributor (in the right side of the engine in th eback flywheel end the vacum hoses in my engine are disconected and i dont have the diagram i searched alot in the web to find the manualof the 3A but just a few things this distributor (inductive) have to vacum inlets that are concet to the inlet manifold to a valve i think but im not sure please add me to help each other if u have camera will be great thx sergio |
07-13-2008, 08:26 PM
Hm... As I remember I didn't saw any vacuum hoses... But I'll check.
I have no msn |
07-13-2008, 09:18 PM
What do you specifically need to know about the AE85?
07-14-2008, 10:26 AM
F0Bman Wrote:What do you specifically need to know about the AE85? well if its posible themanual liek the AE86 with 4age that i already have but my problem now that i have a 3A-U in my AE85 uhmmm well from the AE86 its diferent wiring but can be solved the probelm is the engine i cant find the mannual just found a few data in the autozone page very good indee but mix with the 3E engine and bad scaned pictures well i think the diafragm of the distributor its dead a few holes i think that why the last mechanic disconectd the 2 hoses but i want to reconect allthe vacum hoses that are disconectd but i don know where i have to conect dont have themanual and the diagrams there a los tof vacumhoses disconectd its a mess but the last mechanic surely disconect cause the diafragm its in bad condition maybe cand hold the suction for the diafragm well i not take out the distributor and desemblied yet cause im busy but if the diafragm is the probelm and fix it the i ahve to start from zero and wont know the vacumhoses diagram u canhelp me? have any photos im gonna fix my camera for sure |
07-15-2008, 04:49 PM
sergiocharged
I took a look on my engine. If you still have 2 metal small pipes in the back of the block near distributor - no problems. upper outlet on distibutor connected to upper pipe, lower - to lower. Simple =) But, i this tubes is lost - I can't see where they connected |
07-15-2008, 06:25 PM
Hald Wrote:sergiocharged ????????????????????????????????????????????? in the back of the block nean distributor? like lil jon said Whaaaaaat¡¡¡¡ if u have a camera i really apretiate it cuase i really really dont undestand maybe u think this 2 pipes that ur talkin about is the distributor vacum advance that its one piece unified with the distributor its not part of the block maybe is that but ur saying the upper pipe to another upper pipe and vice versa woth the low one that confuse me alot if u have a camera in ur cellphone i have to buy special batterires for my mines and cost a lot for simple batteries but im gonna do it along time ago i m on my way to the shop |
07-15-2008, 07:39 PM
I'll try to explain. Englih - is not my native language, so it's hard for me to talk clearly =) So, try to understand.
Well, I don't think thet I can make pictures of vacuum pipes, because there is no enought space. You must see 2 short tubes on distributor. This 2 tubes connected to manifold throo 2 pipes, thet goes from manifold in the back of the block. Pipes on the back of the block connected to distributor with 2 rubber short pipes. Just try to find 2 pipes at the back of the block to the right from distributor. |
| Ae85 swap 4age. | Minidaxman | 8 | 8,697 |
04-07-2021 10:16 PM Last Post: Minidaxman |
| ae85 kickdown cable | MIGGZFSU | 0 | 3,959 |
05-04-2017 04:23 PM Last Post: MIGGZFSU |
| HELP! need AE85 lisse/lime cluster diagram | AE86_DRIFTER_ | 0 | 4,498 |
06-27-2016 11:38 PM Last Post: AE86_DRIFTER_ |
| Electrical - Rear Screen Demist and Dash lights | mad.matt | 0 | 4,744 |
01-12-2015 01:15 PM Last Post: mad.matt |
| starting/electrical issues | Jezza_hr | 14 | 22,916 |
12-21-2013 05:45 PM Last Post: Apsogos |
