wheel rim spacer center bore, 60mm ?
01-21-2010, 04:12 PM
Hi all
Trying to find info about diameter of center bore in AE86 wheel. I need i to build spacers. Found some info that it's 60 and 60,1mm. Can someone just confirm me that ? Thanks |
01-21-2010, 05:15 PM
hub diameter is 64,1mm so the centrebore of the wheel can't be less than that
01-21-2010, 05:23 PM
60,1mm exactly!
01-21-2010, 08:10 PM
oops sorry
i mixed something up CSM is right... it's 60,1mm |
Restoring original pizzacutter center caps | banpei | 17 | 9,771 |
06-24-2021 10:58 PM Last Post: banpei |
Rim width. Which is best.... | Dino86 | 5 | 7,009 |
AE86 roll center adjusters for Carina | nyberrg | 9 | 12,750 |
06-16-2015 02:45 AM Last Post: roman |
driveshaft center bearing issue | chenfon | 8 | 13,011 |
11-30-2012 12:06 PM Last Post: chenfon |
trd solid spacer how to? | slowboy2 | 11 | 16,777 |
04-21-2012 08:13 AM Last Post: slowboy2 |
