AE86 from Russia!
08-06-2011, 11:15 AM
AE86 from Russia!
hello guys! Who knows what thickness of headgasket should be in stock?
08-08-2011, 03:10 AM
AE86 from Russia!
it's 1.2mm
![]() SR Team BURN THE RUBER NOT YOUR SOUL! |
08-09-2011, 09:23 PM
AE86 from Russia!
Thanks a lot dude!!!
08-11-2011, 03:00 PM
AE86 from Russia!
Hi guys! I need yours help. Where i can buy metallic head gasket 1,3 mm thickness? Thanks!!!
08-11-2011, 07:04 PM
AE86 from Russia!
Turner from Russia Wrote:Hi guys! I need yours help. Where i can buy metallic head gasket 1,3 mm thickness? Thanks!!! Why 1.3mm? do you want to go on turbo? On ebay you can find some HKS it's are 1.6mm ![]() SR Team BURN THE RUBER NOT YOUR SOUL! |
08-11-2011, 07:37 PM
AE86 from Russia!
I saw 1,6 but i need 1,3 (((
08-12-2011, 09:18 PM
AE86 from Russia!
IBMFD3S Wrote:Turner from Russia Wrote:but i want termostatic oil cooler)) I hope that i can bring my engine to life)))sure about that? i know about a RX-7 (ok not a Hachi) where the engine was destroyed because the thermostat failed ->no cooling. i would never buy a oil cooler with thermostat for my cars because of that reason. Thermostatic valves for oil coolers are very simple devices it would be very rare indeed for one to fail. I've never heard of anyone having a problem. Also running with a non-thermostatic cooler setup is a bad idea as the oil may never heat up. Think how cold Russian winters are! So, I would say a thermostatic oil cooler is an absolute must. Good luck with the car, liking it. ![]() 1985 Sprinter Trueno GT Apex 2013 GT86 Miltek Exhaust, Injen Induction. |
08-14-2011, 02:29 PM
AE86 from Russia!
Thanks a lot ))) but this is my second car and i don't want to use levin in winter time!!! Now i try to win setrab oil cooler on ebay! And todsy i won two apexi el gauges!!! Oil pressure and coolant temp! Very happy )))
08-14-2011, 02:34 PM
AE86 from Russia!
I'd still only run thermostatic. I really wouldn't consider running an oil cooler without it.
08-14-2011, 10:03 PM
AE86 from Russia!
Okey. If i buy serbat cooler i'll try to find thermostatic sandvich)
Zordan vs 2nr Works team AE86 Project (Russia,Moscow) | pernati | 19 | 29,039 |
03-03-2015 05:53 PM Last Post: pernati |
My project from AE85 to AE86 Levin Russia Krasnoyarsk | Val`deMaR | 39 | 38,574 |
08-22-2009 05:53 PM Last Post: Kid Karola |
