AE86 halfshaft types?
11-26-2012, 02:22 AM
Hi,
Can anyone tell me the difference in halfshafts between early and late type? Splines, diameter and lenght? Do non-LSD axles have longer shafts? Tried to search for info but couldnt find it. Thanks |
11-27-2012, 01:33 AM
Can anyone help?
11-27-2012, 02:17 AM
difference in spline/ diameter (kouki 25,3 mm zenki 24mm)
Yes, longer shafts on factory non LSD AE86, which I belive were never sold in Europe! German AE86 cam with a 25% LSD 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
11-27-2012, 10:22 AM
Can AE85 longer shafts be shortened to fit AE86 ?
11-27-2012, 11:08 AM
Yes but not with an angle ginder, cause that fucks up the hardening! Any half decent machine shop can do it
11-27-2012, 01:35 PM
But they are same diameter/spline count, just a bit longer towards/in differential.
Great
11-27-2012, 08:02 PM
Yeap, iirc its about 5mm longer, but I think I remember that this is only a problem if you go with TRD LSD“s? Kaaz and others should work without shortening, but you definalty should confirm this by somebody else...
| Halfshaft freeplay | Blaze0010 | 0 | 1,756 |
11-11-2022 06:36 PM Last Post: Blaze0010 |
| rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 5,630 |
| Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 19,713 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
| Clutch types for AE86 | nmwisima | 38 | 79,946 |
07-03-2010 02:09 PM Last Post: Sam-Q |
| Halfshaft moving in & out - strange problem | max_ae86 | 6 | 8,283 |
05-22-2010 10:16 PM Last Post: max_ae86 |
