AE86 halfshaft types?
11-26-2012, 02:22 AM
Hi,
Can anyone tell me the difference in halfshafts between early and late type?
Splines, diameter and lenght?
Do non-LSD axles have longer shafts?
Tried to search for info but couldnt find it.
Thanks
11-27-2012, 01:33 AM
Can anyone help?
11-27-2012, 02:17 AM
difference in spline/ diameter (kouki 25,3 mm zenki 24mm)
Yes, longer shafts on factory non LSD AE86, which I belive were never sold in Europe! German AE86 cam with a 25% LSD
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
11-27-2012, 10:22 AM
Can AE85 longer shafts be shortened to fit AE86 ?
11-27-2012, 11:08 AM
Yes but not with an angle ginder, cause that fucks up the hardening! Any half decent machine shop can do it Wink
11-27-2012, 01:35 PM
But they are same diameter/spline count, just a bit longer towards/in differential.
Great Smile
11-27-2012, 08:02 PM
Yeap, iirc its about 5mm longer, but I think I remember that this is only a problem if you go with TRD LSD´s? Kaaz and others should work without shortening, but you definalty should confirm this by somebody else...
  Halfshaft freeplay Blaze0010 0 1,045 11-11-2022 06:36 PM
Last Post: Blaze0010
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 3,713 07-25-2021 04:41 AM
  Anyone farmiliar with hks camshaft types for 4age? spill86 5 16,774 11-18-2017 11:36 PM
  Clutch types for AE86 nmwisima 38 71,913 07-03-2010 02:09 PM
Last Post: Sam-Q
  Halfshaft moving in & out - strange problem max_ae86 6 6,899 05-22-2010 10:16 PM
Last Post: max_ae86
