AE86 wheels
03-09-2006, 01:53 PM
Post: #231
AE86 wheels
Those are standard toyota wheels as far as I can tell. Maybe something else on your rear axle isnt standard? What size is that tire? I know 195/60r14 fits for sure.
03-09-2006, 01:59 PM
Post: #232
AE86 wheels
I just brought the Rear End and overhauled it so its my first time putting this wheel on and the axle Smile Its a T283 A86 rear axle i believe but seems studs seem longer than necessary - not sure why they would replace all the studs but its a PIA for me!
[Image: AEU86 AE86 - AE86 wheels]
See the stud T.T I need about 5mm spacer to fit the wheels on.
this is what I originally brought Smile
03-09-2006, 02:53 PM
Post: #233
AE86 wheels
Get open ended lugnuts..
09-14-2006, 09:48 PM
Post: #234
AE86 wheels
15x9 -13 offset with a seriously wide track (Adjustable LCA and Camber Plates pulled out) RS Watanabe R-Type. 195/50/15 Tyre.
Im happy with them.
Driftworks - JSPFab.com - DangerStyle - NightSpirit
09-14-2006, 10:35 PM
Post: #235
AE86 wheels
PazzaAE86
They dont rub the wings?
Heres mine, 15x7 et13 195/50-15
09-15-2006, 05:54 PM
Post: #236
AE86 wheels
Nope. No rubbing.
09-16-2006, 12:46 AM
Post: #237
AE86 wheels
here is mine:
Vladimir
N/A for life...
05-04-2012, 12:42 PM
Post: #238
AE86 wheels
I am looking for some good wheels for track with following criteria,what should i chose?
14 or 15
tires:195/50/15 or standard 14 size for toyota
between 6-7inch,prefer the normal look over the tank '' look
performance > looks and more european style than japanese.
no rubbing wheel arches or inside
affordable.
05-04-2012, 01:30 PM
Post: #239
AE86 wheels
15 inch is the way to go for cheaper tires and wider selection.
For ultimate euro look: Ronal turbo (expensive though).
The dealer optional Atiwe telephone ring style wheels are also a great choice of euro style wheel that will not rub for sure, but they are getting hard to find.
15x7 with an ET around 15 or 20 should fit without rubbing, but others here
should be able to tell you exactly what offset will work.
05-04-2012, 02:10 PM
Post: #240
AE86 wheels
Dont go crazier than 8j et0.
Think you would like 7 et -2~0
