ANOTHER Australian AE86
05-18-2008, 08:46 AM
[Image: AEU86 AE86 - ANOTHER Australian AE86]
Coming Mods:
Engine:
20v BT head + throttles (purchased)
Late 7afe block + crank (purchased)
Belfab 7afe Conrods (purchased)
Stock/Aftermarket? Blacktop 20v pistons
288/10mm 194-D Customized Kelford Cam
KVS51B Kelford Valve Springs
2 x Toda Exhaust Cam Gears
RS Chita Cooling RWD Conversion/16V 4age Waterpump
JR VVT blanking plug + plate (purchased)
1jz 380cc Injectors (purchased)
1zz coil on plugs + new plugs and pins (purchased)
RWD Alternator Mount
16v RWD Alternator (purchased)
AE92 4AGE Starter Motor
Greddy Oil Cooler
Racing Gear Aluminium Radiator
Samaco Radiator Hoses
Cusco Engine Mounts (purchased)
Cusco Transmission Mount (purchased)
Adaptronic ECU tuned by GTgarage
Cusco or Powercraft Extractors
Dart Izumi Exhaust or Trust DD Exhaust *both 1 hotdog muffler thru to twin tip*
Lightweight Pulley Kit (purchased)
JDM Bellhousing + T50 Gearbox (purchased) *but for how long will it last*
Footwork:
Front Coilover - tokico hts102 & swift spring (purchased shocks)
Rear Shock + Spring - tokico hts102 & swift springs (purchased shocks)
Power Steering Knuckles (purchased)
AJPS 40mm RCAs (purchased)
Cusco Castor Rods
Cusco Camber Tops (purchased)
URAS Tie Rods
AJPS Twin Adust Inners + RA40 Tie Rod Ends (Purchased)
XT130 Lower Control Arms (Purchased)
Nagaisa Auto Traction Brackets (purchased)
Custom Equal Length Trailing Arm Boxes (purchased)
Custom Adjustable Equal Length 4 Link (purchased)
Custom Panhard Rod (purchased)
Cusco front and rear sway bars (purchased)
T18 Series II T Series Diff (purchased)
Cusco Rear Roll Centre Adjustor (purchased)
Cusco 1.5way LSD
Techno Pro Spirits 4.7 Rack and Pinion (purchased)
BRAKES
Front
FC3S front caliper (purchased)
QFM A1RM Brake Pads (purchased)
AJPS Caliper Adapter (purchased - BUT FOR SALE)
DELAZY INDUSTRIES Caliper Adaptor (purchased)
Mini Cooper S 276mm Rotors
Braided Lines
Upgraded Master Cylinder *unsure of size yet*
Rear
2 x Vs commodore rear calipers
QFM A1RM Brake Pads - footbrake
URAS/Project Mu D1 Spec Pads - handbrake
DELAZY INDUSTRIES caliper adaptor plates
R31 Rotors (260x11mm)
braided lines
driftworks hydrolic handbrake
Interior:
Black JDM Dash
2x Bride Zeta Sports
Nardi Deep Corn Steering Wheel (Purchased)
T3 JTC STYLE Gearknob (purchased)
T3 Drift Button (purchased shocks)
2x Takata Harness
Alloy Floor Plates (purchased)
Carbing Footrest (purchased)
Carbon door panels
J-Blood carbon door sills
Surge tank mounted in spare wheel well *to be decided*
Bracing:
Cams Half Cage with side intrusion bars
Cusco Tension Rod brace (Purchased)
Nagaisa Auto Shakkaito Plates (Purchased)
Cusco OS Strut Brace (purchased)
T3 tri brace *adds onto cusco strut brace and braces against firewall* (purchased)
Ultra Racing Fender Braces (purchased)
Ultra Racing 4 Link Mid Brace (purchased)
Ultra Racing Bomber Brace (purchased)
Exterior:
Black Work Meister 15x8.5-17 & 9" -29 Sad
4 x Bridgestone Potenza Adrenilin RE001 195/50/15
2 x Bridgestone Potenza RE01 195/50/15 *dreams*
midnight purple paint *inside and out*
Runfree type II full kit (purchased)
JDM Zenki whiteline tail-lights (purchased)
JDM Kouki foglights (foglights and bracket purchased)
JDM Kouki Headlights (purchased)
JDM Kouki Corner Lights (purchased)
Skid Rims:
2x SSR MK-2 15x8.5J- 7 (purchased)
2x SSR MK-2 15x8.5J- 19 (purchased)
CURRENT AMOUNTS SPENT - lost count @ $10,000
Flat Front Ke70
Coming Mods:
mods:
makita superlows
VL excel g's shocks in rear
14x7+/-0 hotwires
stereo
sprinter seats
kierans previous unconditional love
t18 S2 struts + brakes
section cambertops
st184 kyb excel g inserts
6kg/4.5kg springs
xt130 rona arms
ps knuckles
20mm rca
lock spacer
whiteline panhard rod
tercel swaybar + fresh bushes
tyres
fronts - 185/60/14 toyo proxes
rear - 165/65/14 Sava's or watever else i can find
planned
3tc (purchased not highest priority, maybe early next year)
redline intake manifold (purchased)
32/36 weber (purchased)
extractors (purchased)
stage 3 - 264/260 camshaft
double race valve springs
ae71 pedal box (purchased)
s series ae86 diff
mini spool
traction brackets [if i can find them cheap]
CURRENT AMOUNT SPENT - :noes:
will update list as things are added and as things are purchased......
05-18-2008, 09:38 AM
Welcome! Nice looking car and very nice spec list Thumbs up!
05-19-2008, 05:08 AM
possibly a new update...
in talks with the owner of a 5ag bottom end atm....
consisting of ae111 rods (shotpeen'd and balanced), HKS 5ag crank, ca18det pistons and fresh 7 rib block
also included in the deal is a bigport head that was built by rs-yasu featuring 254/262 cams, cam gears and valve springs aswell as a rather heavy port and polish
currently talking to a few engine builders over possible options and will highly likely buy this package within a couple weeks
05-29-2008, 05:54 AM
NUTS!
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
08-16-2008, 01:31 PM
08-16-2008, 02:13 PM
deal on the 5ag gear fell thru Sad
so just buying a 20v and seeing wat pops up in the meantime, been eyeing off a few 5ag crank lately, so might jump on one of those sometime soon
08-16-2008, 02:46 PM
nice car mate Cool
did you remove the front bumper lights?
Do you ever notice that when you're driving, anyone going slower than you is an idiot and everyone driving faster than you is a maniac?
08-16-2008, 06:05 PM
yea, front bumper was only just fitted 20mins before the pics....cbf'd putting them back in
08-16-2008, 06:11 PM
Nice car and impressive speclist. Thumbs up!
ハチロク
09-12-2008, 03:42 PM
  Another AE86, Duracell. Now with VEMS, and cage... Uzelac 62 104,692 06-22-2015 02:56 PM
Last Post: Uzelac
  project "twin cam 16" another AE86... fax0815 11 21,099 11-19-2011 09:05 AM
Last Post: BOOMEX
  Chiro- another Croatian AE86 mrgud 154 180,677 10-12-2009 05:46 PM
Last Post: einneb
  another AE86 around here maggkrabar 44 48,738 08-23-2008 09:51 PM
Last Post: maggkrabar
  Another AE86 build up - Racecar Jan Pedersen 18 24,940 06-09-2008 03:34 PM
Last Post: Jan Pedersen
