ANOTHER Australian AE86
05-18-2008, 08:46 AM
![]() ![]() ![]() ![]() ![]() ![]() Coming Mods: Engine: 20v BT head + throttles (purchased) Late 7afe block + crank (purchased) Belfab 7afe Conrods (purchased) Stock/Aftermarket? Blacktop 20v pistons 288/10mm 194-D Customized Kelford Cam KVS51B Kelford Valve Springs 2 x Toda Exhaust Cam Gears RS Chita Cooling RWD Conversion/16V 4age Waterpump JR VVT blanking plug + plate (purchased) 1jz 380cc Injectors (purchased) 1zz coil on plugs + new plugs and pins (purchased) RWD Alternator Mount 16v RWD Alternator (purchased) AE92 4AGE Starter Motor Greddy Oil Cooler Racing Gear Aluminium Radiator Samaco Radiator Hoses Cusco Engine Mounts (purchased) Cusco Transmission Mount (purchased) Adaptronic ECU tuned by GTgarage Cusco or Powercraft Extractors Dart Izumi Exhaust or Trust DD Exhaust *both 1 hotdog muffler thru to twin tip* Lightweight Pulley Kit (purchased) JDM Bellhousing + T50 Gearbox (purchased) *but for how long will it last* Footwork: Front Coilover - tokico hts102 & swift spring (purchased shocks) Rear Shock + Spring - tokico hts102 & swift springs (purchased shocks) Power Steering Knuckles (purchased) AJPS 40mm RCAs (purchased) Cusco Castor Rods Cusco Camber Tops (purchased) URAS Tie Rods AJPS Twin Adust Inners + RA40 Tie Rod Ends (Purchased) XT130 Lower Control Arms (Purchased) Nagaisa Auto Traction Brackets (purchased) Custom Equal Length Trailing Arm Boxes (purchased) Custom Adjustable Equal Length 4 Link (purchased) Custom Panhard Rod (purchased) Cusco front and rear sway bars (purchased) T18 Series II T Series Diff (purchased) Cusco Rear Roll Centre Adjustor (purchased) Cusco 1.5way LSD Techno Pro Spirits 4.7 Rack and Pinion (purchased) BRAKES Front FC3S front caliper (purchased) QFM A1RM Brake Pads (purchased) AJPS Caliper Adapter (purchased - BUT FOR SALE) DELAZY INDUSTRIES Caliper Adaptor (purchased) Mini Cooper S 276mm Rotors Braided Lines Upgraded Master Cylinder *unsure of size yet* Rear 2 x Vs commodore rear calipers QFM A1RM Brake Pads - footbrake URAS/Project Mu D1 Spec Pads - handbrake DELAZY INDUSTRIES caliper adaptor plates R31 Rotors (260x11mm) braided lines driftworks hydrolic handbrake Interior: Black JDM Dash 2x Bride Zeta Sports Nardi Deep Corn Steering Wheel (Purchased) T3 JTC STYLE Gearknob (purchased) T3 Drift Button (purchased shocks) 2x Takata Harness Alloy Floor Plates (purchased) Carbing Footrest (purchased) Carbon door panels J-Blood carbon door sills Surge tank mounted in spare wheel well *to be decided* Bracing: Cams Half Cage with side intrusion bars Cusco Tension Rod brace (Purchased) Nagaisa Auto Shakkaito Plates (Purchased) Cusco OS Strut Brace (purchased) T3 tri brace *adds onto cusco strut brace and braces against firewall* (purchased) Ultra Racing Fender Braces (purchased) Ultra Racing 4 Link Mid Brace (purchased) Ultra Racing Bomber Brace (purchased) Exterior: Black Work Meister 15x8.5-17 & 9" -29 ![]() 4 x Bridgestone Potenza Adrenilin RE001 195/50/15 2 x Bridgestone Potenza RE01 195/50/15 *dreams* midnight purple paint *inside and out* Runfree type II full kit (purchased) JDM Zenki whiteline tail-lights (purchased) JDM Kouki foglights (foglights and bracket purchased) JDM Kouki Headlights (purchased) JDM Kouki Corner Lights (purchased) Skid Rims: 2x SSR MK-2 15x8.5J- 7 (purchased) 2x SSR MK-2 15x8.5J- 19 (purchased) CURRENT AMOUNTS SPENT - lost count @ $10,000 Flat Front Ke70 ![]() Coming Mods: mods: makita superlows VL excel g's shocks in rear 14x7+/-0 hotwires stereo sprinter seats kierans previous unconditional love t18 S2 struts + brakes section cambertops st184 kyb excel g inserts 6kg/4.5kg springs xt130 rona arms ps knuckles 20mm rca lock spacer whiteline panhard rod tercel swaybar + fresh bushes tyres fronts - 185/60/14 toyo proxes rear - 165/65/14 Sava's or watever else i can find planned 3tc (purchased not highest priority, maybe early next year) redline intake manifold (purchased) 32/36 weber (purchased) extractors (purchased) stage 3 - 264/260 camshaft double race valve springs ae71 pedal box (purchased) s series ae86 diff mini spool traction brackets [if i can find them cheap] CURRENT AMOUNT SPENT - :noes: will update list as things are added and as things are purchased...... |
05-18-2008, 09:38 AM
Welcome! Nice looking car and very nice spec list
![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
05-19-2008, 05:08 AM
possibly a new update...
in talks with the owner of a 5ag bottom end atm.... consisting of ae111 rods (shotpeen'd and balanced), HKS 5ag crank, ca18det pistons and fresh 7 rib block also included in the deal is a bigport head that was built by rs-yasu featuring 254/262 cams, cam gears and valve springs aswell as a rather heavy port and polish currently talking to a few engine builders over possible options and will highly likely buy this package within a couple weeks |
05-29-2008, 05:54 AM
NUTS!
08-16-2008, 01:31 PM
08-16-2008, 02:13 PM
deal on the 5ag gear fell thru
![]() so just buying a 20v and seeing wat pops up in the meantime, been eyeing off a few 5ag crank lately, so might jump on one of those sometime soon |
08-16-2008, 02:46 PM
nice car mate
![]() did you remove the front bumper lights? Do you ever notice that when you're driving, anyone going slower than you is an idiot and everyone driving faster than you is a maniac? |
08-16-2008, 06:05 PM
yea, front bumper was only just fitted 20mins before the pics....cbf'd putting them back in
08-16-2008, 06:11 PM
Nice car and impressive speclist.
![]() ハチロク ![]() |
09-12-2008, 03:42 PM
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 95,820 |
06-22-2015 02:56 PM Last Post: Uzelac |
project "twin cam 16" another AE86... | fax0815 | 11 | 19,344 |
11-19-2011 09:05 AM Last Post: BOOMEX |
Chiro- another Croatian AE86 | mrgud | 154 | 162,699 |
10-12-2009 05:46 PM Last Post: einneb |
another AE86 around here | maggkrabar | 44 | 43,665 |
08-23-2008 09:51 PM Last Post: maggkrabar |
Another AE86 build up - Racecar | Jan Pedersen | 18 | 22,424 |
06-09-2008 03:34 PM Last Post: Jan Pedersen |
