Abby
09-06-2010, 06:17 PM
Post: #51
Abby
try getting the goodridge brake lines from ebay.co.uk there nice and cheap. 60 pounds all around
09-06-2010, 06:33 PM
Post: #52
Abby
robokill Wrote:try getting the goodridge brake lines from ebay.co.uk there nice and cheap. 60 pounds all around Got mine there too after suggestion from robokill ![]() 1985 AE86 (ハチロク) Levin - Summer time daily driver |
09-06-2010, 08:21 PM
Post: #53
Abby
i got the also on my hachi, and they work very fine!!
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
09-06-2010, 08:24 PM
Post: #54
Abby
Thanks for the tip!
09-06-2010, 08:29 PM
Post: #55
Abby
they are cheaper if you compare to somewhere else in The Netherlands
09-06-2010, 10:32 PM
Post: #56
Abby
Good luck tomorrow! I like what you did with the exhaust.
09-08-2010, 05:21 PM
Post: #57
Abby
We haz MOT!
![]() ![]() ![]() Now just a couple more days for the "road permit" and we're all set ![]() ![]() |
02-20-2011, 06:05 PM
Post: #58
Abby
Aaight, couple of months have passed....... "new" engine started to develop some blue and white smoke, so... based on my new experiences it might be a blown headgasket
![]() Anyways, during x-mas holiday I have been taking the "old" engine apart.... turns out nothing was really wrong with it.. Just a blown headgasket. Meh, if I hadn't tried to get some mileage out of the 1 year warranty, I could have done with just replacing the gasket.. as it is now, it's on to a simple rebuild with some new oil pump and water pump and gaskets. Anyways, here some pics: Head being taken apart ![]() Cams are out ![]() No cams ![]() Head on bench ![]() Blown gasket between 3rd and 4th cylinder ![]() Nothing interesting at 1st and 2nd cylinder ![]() block overview ![]() flipped head (I probably shouldn't have done this without removing the buckets first....) ![]() Now on to something I came across after having the engine apart on the bench for a couple of days... didn't notice these scratches at first, so I'm wondering how they came there and how bad this would be when putting back the engine together: exhaust, 1st cylinder camretainer ![]() same camretainer, different angle ![]() exhaust, second retainer, looks like dirt mostly, or some pitting? ![]() exhaust, head journal, hmmm 3rd one iirc ![]() check all images here: http://www.cavey.nl/images/ae86/4age_rebuild/ So, just wonderirng. Something to worry about, these little marks, or just clean it up and slam it back together? Couldn't feel anything with my finger/nail, so it "seems" flat/flush... but well, seems to be softish material and when running under rpm's... (oh, the rattling I detected and asked about is most likely caused by the exhaust mounting... ) Where to go from here? I've been thinking about cleaning up the head first, removing the valves (got one of those little valve removel tools) and then? Any tips/tricks/ideas on decarbing, degreasing etc? After the head is done, I'll start on the block. Still need to remove the crankpulley, and then I can take it from there. ![]() |
02-20-2011, 09:39 PM
Post: #59
Abby
Your cam bearings look ok,
I´ve got a few deeper scratches on my cam bearing, gave them a little wetsanding, checked the clearance, all good! If I were you I´d take the valves (good tools are expensive), and valve steam seals out (cheap tool around 30€). Get the head to a engine shop the get the head shimmed, and if you got 50€ left get the valves and valve seats machined, after that the put the head into the huge washing machine and it will come out like new. I´d clean the block surface with a scraper sand paper. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
