Adam's volvo 242 nonsense
10-16-2018, 08:40 AM
At least the swedes used decent steel.. Easier to work on than most jap-tin from the same period.
You can also see how the car comes apart like lego for ease of work. I love those bricks. The engines are also very reliable.. I think the rust doesn't look too bad.. just get the ugly bits sandblasted and save yourself the hassle of cleaning it if you can. I'm fairly certain there's enough healthy steel left in most places. FABRICA MI DIEM, PVNC! |
10-17-2018, 06:35 PM
Hey Ivan!
Yeah, the steel is great! And all the bolts are made properly too as i have never broken any yet haha. The rust treatment will be considered when i have a chance to see the underside of the car. Cheers |
12-29-2018, 11:34 AM
(This post was last modified: 12-29-2018 11:37 AM by Rascal21.)
(10-14-2018 12:57 PM)adomz Wrote: Destiny works in mysterious ways, this gave me an idea for TA40 leaf-spring rear end>4-link rear end conversion. Thx ![]() Volvo's are awesome, been following a certain Canadian Volvo enthusiast on Youtube for a few years now and have seen what he can do with non-turbo+auto+open diff Volvo's when he's pretty much stoned. For reference: https://www.youtube.com/watch?v=2QPBSqnOAdo I have been drifting a friends turbo 940 wagon (open diff) a little. The minimal effort needed in getting and keeping that thing sideways on ice/snow is staggering. With that as a reference, if the only thing you ever do to this car is rust welding and some coilovers with Bilstein inserts and 16v+turbo conversion you have an insane car already, much less with a LS400 rear subframe assembly! ![]() Honestly that rust isn't hard to stop, and your Volvo is a battle master tank. I have an AE86 in my shed that's FAR worse and it can still easily be saved. All that structural rust you're seeing on the rear axle brackets on the body is mostly surface rust on some seriously thick steel construction, it's pretty much harmless surface rust easily taken care of by a wire-wheel on an angle grinder then some "rust milk" splashed on and spread out by hand for quick measure before you paint it, bathe it in some Wurth zinc spray, then some black Corroprotection spray paint, then spray 10-15 boxes of that rough surface protection (the plastic kind of stuff that wrinkles up when it dries) that they usually just change the brand and name on for every cheap autostore in every country (in Scandinavia its Biltema, in the U.S its Harbor Freight and so forth) and it should be good to go. I've seen Volvo's slam into street lights fully sideways at 60-70kph and still be structurally sound (in comparison, most BMW's get bent all out of shape when lightly clipping into said street light or rear wheels hitting curbs sideways in roundabouts at far less than half that speed), so don't be too bothered by those rocker panels, they're just formal aesthetics for a Volvo. Just get some 1mm thick plates breaked up in a 20-30 degree angle so you have something to work with, just use the edge right under the door as reference and keep cutting all the way, use some magnets to hold the b*tch in place and spot weld every 3-4cm. If you ask me even that is too much, I can pretty much count the amount of factory spot-welds on older cars by mind, and they still need to be 50% gone to actually be structurally unsafe. Seen cars with rocker and wheel arch repairs mostly held together by Fusor body-glue and the metal broke AROUND the glued areas! Don't bother making the profile where rocker's meet perfectly round as from factory. Smooth out the edges before rocker meets front and rear wheel arches with some bodyfiller = good enough for that Swedish battle machine ![]() For the LS400 sub-assembly just modify it until it fits the volvo floor with just some holes drilled through, that's what they did at the factory anyway, it just looks fancier. Some plates welded in up top on the floors inside the car should make sure it doesnt budge even with 700hp. Just use what you got and make it count, if you start nitpicking on this car you'll never drive it, if you smash it up just bring the 16v and LS400 stuff over to a 940 or something ![]() 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
01-05-2019, 04:00 AM
Hey dude! Never realised to see such a writeup on the 242 haha
![]() I do know Drifts N Lifts fora while and we do chat around from time to time whenever the time comes, so it's cool to see someone appreciate what he does. Whenever the time comes (very soon), the 242 will be disassembled to bare shell and investigated to see the work that needs to be done and then i will do all necessary stuff to make itall as new as i can asi am planning to keep this car for as long as i can. I can't just throw itall together and hope itlasts and get anotherone as it's almos unobtanium where i am... So Yeah, shit's gonna get done whenever it happens, and you shall see it all here ![]() Cheers, Adam |
05-10-2020, 08:55 PM
(This post was last modified: 05-10-2020 09:13 PM by adomz.)
One day i brought the 242 home and realised that we are struck by the covid 19 nonsense....
And then i went to my garage and started filming!! And t hen i got hooked!!! (12-29-2018 11:34 AM)Rascal21 Wrote:(10-14-2018 12:57 PM)adomz Wrote: Hey buddy!! There you go, the documentary has started!! You can see what i have here!! ![]() Please enjoy! ADam |
05-11-2020, 07:04 PM
If you have an old Volvo then I think you're now qualified to become an officer in the RAF. j/k
Great job on making progress and documenting it, looks like you're having fun too. |
05-11-2020, 07:38 PM
Hey! Yeah man, loving it! Just struggling with space as there's 2 cars i the garage currently, but i think it will change in a month or two.
Cheers! |
05-22-2020, 10:55 PM
(This post was last modified: 05-22-2020 10:56 PM by adomz.)
05-25-2020, 09:52 PM
Lovely jubbly.. mostly rotten where it looks like it is relatively easy to fix.
05-26-2020, 03:06 AM
Adam's volvo 242 nonsense | |||
Adam's white, rusty levin...updated 23-09-2018!! | adomz | 150 | 164,325 |
09-23-2018 05:14 PM Last Post: adomz |
