Adjusting handbrakes (+ back up light with pictures)
05-15-2005, 01:53 AM
Hello All,
I'm new here and have already a question for my Hatchi. I want to adjust the handbrake cable for the right side of the car. I already have a new cable on the left, but now the right side wouldn't lock? Is it possible to adjust only the rightside? |
05-15-2005, 10:15 AM
http://www.aeu86.org/viewtopic.php?t=194
Download these two babies, Im sure you will find instructions for adjusting the handbrake there ![]() |
05-15-2005, 12:36 PM
I already downloaded the 2 babies, I think the other brake cable is to long. I just want to try to fix this for thuesday. Then the RDW will check the car and I get registration papers.
05-16-2005, 11:12 AM
Welcome!
![]() Did you import the car, since the RDW is going to check it? ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
05-16-2005, 11:33 AM
Yes, I imported the car from Poland, they take all crap to Poland and I try to get back the good stuff.
They we're building the car up for Rallying but they run had no time/money to finish the project. But I will give an introduction + pictures in the new members section. I repaired the handbrake already, I pulled out the brake pads and replaced some bolts. The previous owner didn't like the original toyota bolts in it I think :wink: . But one more thing, the 'back up lights' (for rear driving) doesn't work on the moment, and in the manual was something about a sensor. Is it located on the gearbox itself? Or does have someone have a picture? |
05-16-2005, 11:35 AM
I think the best thing to do, is changing the cable on the right side too. They have a tendensy to be to long... My handbrake doesnt work to good either, and im pretty sure thats caused by the cables being to long
![]() Youtube Myspace and I´ll Google your Yahoo |
05-16-2005, 12:01 PM
The sensor for reverse is easily swapped from outside the gearbox. Jacik the car up and you'll see it. I think its on the left side of the gearbox.
05-16-2005, 12:12 PM
My reverse lights are also not working...I havent fixed it yet but I think it might just be a matter of putting the switch on the gearbox back in position.
05-16-2005, 12:34 PM
Right and left handbrake cable isn't the same. Wire is the same, but outer part is longer on right side of the car.
I have the same problem, and when rebuilt rear calipers, and replace one brake cable, problem was solved. Hand brake is working like hell. I don't need to use to much force on it, but rear wheels are blocking. ![]() 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
05-16-2005, 02:02 PM
left side is a bit difrent inner cable is same lenght only the rubber is difrent the rubber from the left side is slightly longer than on the right.
You really can't adjust the damn thing its simple as locking or not you can rebuild the entire handbrake and let me tell you if you get 2 new cables its a very eazy one to use :-). You can oil the clamps on the calipers they tend to stuck or go bad in time. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,102 |
04-25-2022 04:25 PM Last Post: gh0st |
Detailed LHD engine bay pictures | Bean | 0 | 3,041 |
08-05-2018 04:09 PM Last Post: Bean |
back camber of CBY | roiz86 | 5 | 8,838 |
03-24-2013 02:00 PM Last Post: roiz86 |
Boost Gauge help with Pictures | Okami | 42 | 39,326 |
10-17-2011 05:34 PM Last Post: Okami |
e-brake adjusting mechanism not working! | fax0815 | 3 | 4,833 |
09-06-2011 09:16 PM Last Post: fax0815 |
