Adjusting headlight height
10-26-2006, 02:46 AM
It's probably stated somewhere in the user manual but I'm being lazy and cant be bothered to do a search for it, but how do you adjust the headlight height on a Trueno? I dont mean the motorised system but the height in which the lights shine on the road. I'm having a great deal of trouble seeing into the distance on a really dark night and I end up braking a bit late for corners. Little help?
10-26-2006, 09:01 AM
There are four screws visible if you remove the black plastic cover up front. Two are fixing the light on to the bracket (you can see it holding it) and two are very long screws. The last two are there to adjust the lights. Wink
I advise you to use an electric screwdriver to adjust the lights: they take a lot of windings to adjust. Big Grin
[Image: AEU86 AE86 - Adjusting headlight height]
10-26-2006, 09:28 AM
Lights on all AE86's are bad due to design of headlight.
10-26-2006, 05:24 PM
richieu Wrote:Lights on all AE86's are bad due to design of headlight.
That's why you need to install some auxillary lights. Big Grin Big Grin
  STL file for the early spec Levin headlight ball joint plastic clip DaLanZhu 2 683 04-26-2025 03:24 PM
Last Post: DaLanZhu
  AE86 Headlight + wiper wiring (levin) bozu 11 17,646 09-19-2017 02:06 PM
  Trueno headlight help kazi 9 13,721 04-20-2017 09:37 AM
Last Post: kazi
  TRUENO - LHD headlight solutions pack 11 14,963 09-21-2016 10:29 AM
Last Post: pack
  Peculiar headlight issue - main beam Jezza_hr 3 6,352 10-04-2015 09:25 PM
Last Post: Jezza_hr
