Advice needed on parts!
03-01-2013, 08:42 PM
Right I finally got my 86 off of the road for a bit of a freshen up, the top of my list is getting the diff rebuilt. I am planning to get the diff out myself and send it to a specialists to be rebuilt and then re-install myself.
I've done a little bit of research and have read its pretty simple other than removing the half shafts. Basically what I wan't to know is what parts/seals would you replace for good measure along the the way?
Also any tips wouldn't hurt!
Thanks.
03-01-2013, 11:28 PM
Replace all gaskets.. Toyota sell a complete gasket kit for the rear axle that has pretty much anything you need.
The only other seals to replace are in the pumpkin, and I assume your having that done buy the specialists you mentioned.
03-02-2013, 12:06 AM
When the time comes to replace the complete diff unit into the axle casing
put the big round gasket onto the diff unit not the axle casing :wink:
03-02-2013, 03:00 PM
Thanks guys, just been to Toyota and ordered a gasket set for the rear axle £5!
Is there any parts like bearings (non diff related as i assume my diff builder will tell me what i need here) that aren't ridiculous money that would be a good idea to purchase?
Thanks.
03-02-2013, 09:39 PM
Wheel bearings are the only ones left outside the pumpkin, and they are silly money. Good thing they last quite a while normally.
  Brake advice - master cylinder mannix20vt 12 13,907 08-21-2017 03:21 PM
Last Post: Project D
  Engine advice needed spill86 14 15,635 09-15-2015 10:43 PM
Last Post: spill86
  coilovers advice robotype 23 22,124 05-21-2013 10:18 PM
Last Post: Jan Pedersen
  few issues after last drift days, advice needed fax0815 3 4,677 08-26-2011 08:33 AM
Last Post: jondee86
  KE70 Tuning Advice! Allexz 13 15,514 11-20-2010 01:55 PM
Last Post: Allexz
