coilovers advice
05-16-2013, 08:09 PM
coilovers advice
My advice to you is to save up your money and when you have enough sale this set up and go for greddy, tein or the most affordable one Megan isn't bad for dd either. You can't go wrong with those set up!!!
05-17-2013, 11:14 PM
coilovers advice
Spitfire Wrote:I'm using a longstroke setup with 5.2 kg/mm and yellow Koni's atThis man speaks the truth... Cheers... jondee86 |
05-21-2013, 10:18 PM
coilovers advice
jondee86 Wrote:Konis will do no good for comfort imo. Get some better dampers and it will change a lot. Problem as I see it is that Koni don't adjust both bound and rebound. To keep the car stable you end up with dampers set to something that is harder than what you really want.Spitfire Wrote:I'm using a longstroke setup with 5.2 kg/mm and yellow Koni's atThis man speaks the truth... Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
Brake advice - master cylinder | mannix20vt | 12 | 14,752 |
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 6,544 |
06-05-2017 10:03 AM Last Post: nyberrg |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,902 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 27,187 |
04-04-2017 02:40 AM Last Post: hachirokkos |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 12,421 |
09-05-2016 12:28 PM Last Post: mad.matt |
