Carina drivers! - Coilovers for a TA60/62
05-08-2017, 10:45 AM
Hey!
What coilovers are you running on your cars? What can be modded to fit? What fits?
My struts have a 90mm spacing between the bolts connecting it to the knuckle and each bolt in the strut tower is 107mm apart
I have heard s13 coils might work with some mods. I assume that I would need to buy a set of coils that dont come with hubs and weld the bottom of my own strut to the coil.
Tell me what you know, thanks!
05-24-2017, 10:28 AM
Hi,
I have an TA60 Celica, it is the same platform as the Carina. I know the following:
FRONT
S13 camber plates work with minor adjustments of the bolts. MA6x Supra camber plates don't work.
For the bottom you should get a rolling center adjuster. The only ones I know of are manufactured by T3. AE86 ones DON'T work.
I think the easiest is to get 2 sleeves from https://www.rallydesign.co.uk , cut and weld your strut, get short stroke shocks, here is a complete guide
http://club4ag.com/faq_and_tech_pages/Sh...ersion.htm
REAR
You can use AE86 coilovers, they bolt up if I remember correctly. I personally decided to go on the cheap way for the rear and just got a pair of yellow Koni shocks (AE86 ones) and stiffer springs (Nissan 350Z early models work fine, and they are 6.1 kg/mm, got them for like 30 euros on ebay for a pair).
06-05-2017, 10:03 AM
(05-24-2017 10:28 AM)domi007 Wrote:  Hi,
FRONT
REAR
MA60 roll center adjusters fit my carina. Currently run those. I was thinking of ordering custom BC Racing ae86 coils with s13 camber plates and then get ae86 knuckles to bolt them in the bottom.
I dont know if the knuckles will fit yet though. There may be some spare ones in my garage but i got some sudden engine issues to sort out first
Skickat från min ONEPLUS A3003 via Tapatalk
  Carina TA63 GT-TR - Suspension?? danny 86 11 9,700 01-30-2021 03:39 PM
Last Post: danny 86
  Fitting driftworks CS2 coilovers bozu 2 5,188 05-30-2017 10:50 AM
Last Post: bozu
  D2 Coilovers any good? heshan 18 28,336 04-04-2017 02:40 AM
Last Post: hachirokkos
  TA60/TA62 Carina; what fits? nyberrg 10 17,203 10-12-2016 12:57 PM
Last Post: The Doctor
  Has anyone tried BC Racing coilovers? AlexKTM 9 12,970 09-05-2016 12:28 PM
