Ae86 Horsepower Calculation....
08-29-2009, 06:23 AM
i took the time to figure this out......i hope this will help you guys out in your projects.... 4ac's - 2jz's
these are (( rounded figures )) in what you need in Horsepower in 1/4 mile times....
The Elapse Time Method:
This method uses the weight of the car and the time it took that car to travel 1330 feet (¼ mile).
The formula is: hp = weight / (ET / 5.825)3
avg ae86 body coupe/hatch 2400lbs avg fat/muscle person 200lbs = 2600lbs
((( these times are based on a 2600lbs car if its lighter or heavier your HP will change)))
and yes variables to apply equipment,weather, & how power is applied...
7.0 sec = 1498 hp
7.5 sec = 1218 hp
8.0 sec = 1004 hp
8.5 sec = 837 hp
9.0 sec = 705 hp
9.5 sec = 599 hp
10. sec = 514 hp
10.5 sec = 444 hp
11.0 sec = 386 hp
11.5 sec = 338 hp
12.0 sec = 297 hp
12.5 sec = 263 hp
13.0 sec = 234 hp
13.5 sec = 209 hp
14.0 sec = 187 hp
14.5 sec = 169 hp
15.0 sec = 152 hp
15.5 sec = 138 hp
16.0 sec = 125 hp
16.5 sec = 114 hp
17.0 sec = 105 hp
17.5 sec = 096 hp
18.0 sec = 088 hp
18.5 sec = 081 hp
19.0 sec = 075 hp
19.5 sec = 069 hp
20.0 sec = 064 hp
[Image: AEU86 AE86 - Ae86 Horsepower Calculation....]
Reppin' the old skool....Drive Drift Dream
08-29-2009, 02:06 PM
You do realize that tires, suspension setup, engine build up, chassis, drivetrain, gearbox(Ratios, automatic gearbox turbine ect.) and about everything else also has an effect on your 1/4 time? Not even mentioning the driver. Cant really just count on the horsepower mate.. Just use a dyno man.. Cool
08-29-2009, 07:18 PM
yes i do realize that weather, equipment and how power is applied comes into play......
but if you sit there and do the math....the figures will come close.....
as a matter i ran 14 w/ my GZE and my hp is around 180's...so its pretty damn close
this method is not the most accurate but a pretty good base line in horse power....so people can figure what is needed
when you got figures ...you come & talk
actual weight
trap speed
elapsed time
08-29-2009, 09:53 PM
ae86driftmaster Wrote:avg ae86 body coupe/hatch 2400lbs avg fat/muscle person 200lbs = 2600lbs
What? Either every specs page and my car's papers are really way off, or you might have mixed up something there.
08-30-2009, 01:19 AM
how much do you and car weigh at? and how fast you gone the track?
  Final drive calculation. Aram 31 33,499 12-24-2014 03:08 PM
Last Post: Uzelac
