Ae86 Irish style..You gotta see this
09-23-2005, 12:07 AM
This is a few pics of probable the best drift prepared Ae86 going and that includes Japan .
Owner and builder of this fantastic car is Darren McNamara,Ireland Darren will be competing in the D1 GP at Silverstone on Oct 2nd and along with Eric O'Sullivan in His 20v Corolla Car Spec Engine: SR20DET Conversion Custom McNamara wiring loom Greddy Puller Kit 3 Core McNamara custom "V" mount Intercooler with 3' piping 3 core McNamara custom "V" mount Radiator with custom Alu Header Tank Custom Samco Silicone hose kit Twin Pacet Competition Fans HKS Tubular Manifold Trust Turbo outlet Blitz Nur Spec Exhaust System Forge adj. actuator running 0.9 Bar Boost Toda Racing 5kg flywheel Custom McNamara engine mounts Modified sump to clear steering rack Lightweight altenator Nismo Oil Cap Stant Hi-Pressure Rad Cap Sard Racing Iridium Race Plugs Transmission: Nissan 180sx Gearbox with modified casing to clear tunnel Toda Racing Paddle clutch Toda Racing Strengthened Pressure Plate Custom McNamara Gearbox Mount Nismo Solid Shifter Custom McNamara Lightened and balanced one piece Prop shaft Undisclosed rear axle Locked Differential Interior: Fully Stripped out and lightened OMP ARS bucket seat FIA seat brackets Williams 4 point 3' Harness OMP Corsica steering wheel Sparco Group N Snap off Boss Defi Link Control Unit 2 Defi BF Boost Gauge Defi BF Oil Pressure Gauge Defi BF Water Temp. Gauge Defi 0-9 Tachometer Nismo GT Gear Knob Custom McNamara Centre Console Custom Aircraft switches Varley Red Top Race Battery Fibreglass Battery Box Sprayed Audi A8 Silver Exterior: Vertex Body Kit CBY Overfenders Carbon Fibre Bonnet Custom McNamara "Big" wheel wells Kouki Redline Tailights Kouki Headlights Kouki Inner Fog Lights Fibreglass Tailgate TRD rear wing Sprayed Imperial blue Finished in McNamara Motrorsport Livery Brakes: Custom Brake Lines Goodridge Hoses Black Diamond Slotted Disks Brand New AE86 Calipers all round Project Mu MAX 900 Pads Vertical Hydraulic Handbrake Wheels & Tyres: Compomotive ML's 15x8 ADVAN A048R 195/50/15 (Front) KUMHO Ecesta 195/50/15 (Rear) Fueling: Custom McNamara SSB Alu Tank Sytec FSE Fuel Pump Sytec FSE Pre-Line Bullet Filter Steel Braided Fuel Lines Running Through Car Chassis + Setup: Fully seal welded Pop Riveted Chasis Rails Custom McNamara 9 Point Roll Cage T3 Four Link Kit T3 Adj. Panhard Rod Whiteline Traction Brackets Largus D1 Spec rear Anti-Roll Bar TRD rear ARB Poly Bush Kit Powerflex Rear ARB Link Bush Kit Whiteline Race Spec front Anti-Roll Bar Powerflex Front ARB Link Bush Kit T3 Roll Centre Adjusters Quaife RHD Quick Rack Ueo Style Adj. Track Control Arms Ueo Style Inner over angle Tie Rods Ueo Style Outer Tie Rods TEIN Tension Rods McNamara Front Coilover Suspension Conversion Tokico HTS Shock Absorbers McNamara Drift Spring Kit TEIN Camber Suspension Tops CUSCO OS Front Strut Bar T3 Front Tri-Bar CUSCO OS Rear Strut Bar CUSCO OS Rear Tri-Bar [/img]http://i23.photobucket.com/albums/b389/Joeabc/DSCF0179.jpg[img] |
09-23-2005, 12:10 AM
Few more pics of the car
09-23-2005, 12:12 AM
09-23-2005, 12:17 AM
beautiful
09-23-2005, 12:35 AM
Thats a real nice bit of kit looking forward to seeing it for the first time.
Regards Ian. |
09-23-2005, 12:42 AM
vertex bodykit with cby fenders?
09-23-2005, 02:36 PM
That's no long an AE86! That's a SE86.
Looks very nice. I really like the location of the intercooler. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
09-24-2005, 12:31 PM
Thats one modded AE86...strange how the air comes in under the intercoooler then through the core. I wouldnt think it would get as much flow as mounting it in the normal position. Very cool car.
I once read that you shouldnt believe everything you read. |
09-24-2005, 06:29 PM
But it does help to keep the airflow to the radiator going.. There is a scoop under the intercooler that directs air into it, the only thing I'm missing is a vent in the bonnet above it to get the warmed up air back out of the engine bay.
09-24-2005, 08:30 PM
What a monster!!!
How much did you paid for you TOYOTA AE86??? | kennedy8383 | 11 | 12,069 |
09-07-2011 09:16 PM Last Post: fax0815 |
TRD style Coupe wing | KristianAE86 | 17 | 28,305 |
07-16-2010 04:35 PM Last Post: Spitfire |
Our new AE86 blog for all you ae86 fans! | Garth Ivers | 27 | 24,701 |
02-09-2009 05:12 PM Last Post: Garth Ivers |
irish AE86 festival first of 2008 | MARK_GT-APEX | 17 | 17,383 |
04-22-2008 09:58 AM Last Post: banpei |
cars that so sad to see in the wrecking yard | 4agze | 8 | 8,596 |
03-18-2008 10:23 AM Last Post: jamiemirror |
