Ae86 bulk head mod to fit hydrolic clutch?
11-24-2014, 04:06 AM
I was lucky enough to snag an '86 GTS shell with all of the parts and rebuild engine for $1500. I am going to swap all of the parts to my 85 sr5.
As I look at different write ups for swaps I find more and more little tidbits the last write uo did not. I just cam across a thread that said to put in the hydrolic clutch from the GTS I will need to make a Modification to the bulk head.
I have googled my fingers off and couldnt find an explination of what this modification is.
Any help with explaining this would be much appreciated
Thanks,
Frank
11-24-2014, 10:00 AM
Probably nothing more than drilling a few correctly positioned holes.
11-24-2014, 10:08 AM
Thats what im hoping for. Once I strip the shell and my car I will look around for differences.
11-24-2014, 04:06 PM
the only thing i can guess is that in case of a 3A engine, there might be a cable operated clutch instead of a hydraulic, it could be that, but i'm not sure if the american SR5s got a cable clutch box. If it is, it might be interesting for KP61s and other k-powered cars, as it's the same box, but with a 4A bellhousing.
11-24-2014, 08:42 PM
I just replaced my clutch master and slave cylinder dont those only exist on a hydrolic clutch? Im not sure if I have ever worked on a car without one. But that is what the mod is for; going from a cable clutch to a hydrolic one
11-24-2014, 10:23 PM
yes, if you've changed the master and slave, there's nothing else you need to change, because you allready have the right gearbox/hydraulics in the car atm.
So the bulkhead thing is probably for a cable clutch operated car, which aren't very common outside of Japan anyway.
11-25-2014, 04:01 AM
Awesome! Thanks for the confirmation!
11-25-2014, 07:25 PM
maybe not.........
The SR5 hydraulics are mounted on the left side, because the single cam 4AC's exhaust goes down the right side. This means you need to find a hydraulic line to fit to the bell on the other side now.
Dan -
11-25-2014, 09:21 PM
Do you think that could be as simple as getting a longer clutch line?
  Mistlamps don't fit gh0st 1 2,246 10-14-2021 09:00 PM
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,360 09-08-2021 12:48 PM
Last Post: Ryo
  Q, BMW E30/E36 front struts for a fit? Allexz 7 8,574 03-18-2013 11:18 AM
Last Post: Lajoosh
  Interesting 20v cam cover mod banpei 3 8,873 05-31-2012 02:44 PM
Last Post: Kid Karola
  Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, dsrturbo 2 5,850 07-28-2011 10:51 AM
