Ae86 tacho
01-26-2017, 12:49 AM
Ae86 tacho
Hi there, on my engine swap wiring i,ve was trying to wire check engine lamp on dash and by mistake i aply 12v positive on the tacho signal dash wire. Since now my tach is dead.
How can it be fixed? Cheers |
01-26-2017, 06:21 PM
Ae86 tacho
Oh dear! I'm selling a set of clocks if that helps.
01-26-2017, 09:52 PM
Ae86 tacho
I don't know of any reason why applying 12V to the tacho input wire
would cause it to fail. But since you have done a 4AGZE DLI conversion, you are most likely trying to get the tacho to work with the 4AGZE igniter tacho output... and that won't drive the tacho. AFAIK the 4AGZE tacho output is low level (5V) and the AE86 tacho needs a voltage spike (>30V) to make it work. You will need to either change some resistors in the tacho driver board, or obtain a voltage spike from the negative terminal of both coils and combine the output using diodes. You can find information for both methods on the interweb. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
01-27-2017, 01:31 AM
Ae86 tacho
I,ve already made the resistor things and it was working fine. I realised it doesnt work either blower fan and reverse lights so i guess its maybe a broken fuse. I will check them tomorrow.
Cheers |
01-30-2017, 06:25 PM
Ae86 tacho
Finally checked all wires from both conectors and realised red and blue wire (power) was missed. I wire another power wire attached to it and everything works fine now
Funny thing is the good point to fix it was an jondee answer on another forum? Cheers |
Tacho wiring for 20V | Bentley | 6 | 18,652 |
07-20-2013 11:09 AM Last Post: fax0815 |
tacho issues using haltech e6x on 4ag 20v | bluehachi | 5 | 7,771 |
06-05-2013 06:34 PM Last Post: Rasteirinho |
cool tacho | totta Crolla | 2 | 4,172 |
03-11-2013 10:15 PM Last Post: banpei |
Tacho Signal Levin Coupe with pics | Okami | 10 | 15,432 |
05-31-2010 08:56 PM Last Post: Ivan141 |
tacho signal wire | totta Crolla | 7 | 14,167 |
04-12-2010 09:44 PM Last Post: Okami |
