Aftermarket or used oil cooler ?
07-17-2006, 09:24 AM
Dreja, just shortcut the oil cooler lines.
You don't need the oil cooler for easy driving until you fix it. BR ZaX Drifting - best fun you can have in your car with your pants on! |
07-17-2006, 10:37 AM
firehawk
That’s the wrong way to install a cooler...... . The original sandwich plate is a "pressure valve", it means that only if you have excess pressure the oil goes trough the oil cooler, it is not a full flow sandwich plate. This is not good, because as your oil warms up the oil pressure goes down, and less oil goes trough the cooler.... |
07-17-2006, 06:03 PM
gon Wrote:firehawk That’s the wrong way to install a cooler......I know. We were going to change it but then sold the car and built a new AE82. In the picture, the oil cooler is also upside down - with the hoses down, there's a possibility that some air will remain at the top of the cooler and it won't operate at full efficiency. The other way around, the cooler would sort of "bleed itself". |
Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 54,673 |
Oil cooler | totta Crolla | 0 | 1,534 |
Aftermarket / Additional Foglights | decryphe | 6 | 9,289 |
07-08-2017 08:45 AM Last Post: banpei |
Oil cooler kit | izanagi | 7 | 8,551 |
Permanent oil cooler vs thermostat | Lt86 | 19 | 20,569 |
03-28-2015 06:54 PM Last Post: Lt86 |
