Air temp. sensor placement
01-14-2011, 11:21 PM
Just need confirmation that placing the air temp sensor here will work ok.
[Image: AEU86 AE86 - Air temp. sensor placement][/img]
Obviously I will need to drill a hole in the intake.
Or maybe right down by the neck of the air filter but sill on the intake pipe of course.
http://86life.wordpress.com/
01-15-2011, 01:24 AM
That is exactly where I put my intake sensor, and it worked fine. Use
the rubber grommet that comes out of the AE92 airbox.
Cheers... jondee86
01-15-2011, 03:41 AM
Thanks! Would it make any difference whether I put it on the intake end or the filter end of the pipe?
01-15-2011, 03:47 AM
Nope... same air both places. Anywhere in the intake duct that you
can reach with wiring will do.
Cheers... jondee86
PS: You driving your car yet ?
01-15-2011, 03:52 AM
Very soon. Would have done the cert last week but guy was on holiday. Hopefully organize something this coming week. I have a carbon bonnet coming shortly but hopefully it won't require a cert.
  Fitting Air Con (No PS) to LHD AE86 pack 7 5,375 01-07-2024 11:36 AM
Last Post: CCB
  Lambda sensor wiring sam3007 10 5,954 05-23-2022 10:00 PM
Last Post: The Doctor
  Air Cleaner Assembly Hama86 7 10,375 10-29-2018 03:28 AM
Last Post: Hama86
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 19,644 08-16-2018 01:36 AM
  Placement location fuel filter bozu 0 3,894 12-01-2016 11:06 AM
Last Post: bozu
