American Rally 86 UPDATE
04-02-2009, 09:10 PM
Post: #41
Yeah, I looked at yours and said, "Hey! I can do that!" lol
I had wanted to do it, but wasnt sure how to execute it. Then I saw your build, and liked how you made yours. Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
04-03-2009, 05:22 AM
Post: #42
hehehe, yours is much neater though
![]() just dont roll it like i did mine Brake with the left hand, steer with the right foot... |
04-03-2009, 07:18 AM
Post: #43
Yeah.... It'll happen eventually though... or I'm not going fast enough
![]() Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
04-06-2009, 01:09 PM
Post: #44
Dude, are you going to throw the car from a cliff while you're in it?
That roll cage has more steel in it than the whole car chassis! Although that's the safe way to go, I guess! ![]() |
06-11-2009, 07:46 PM
Post: #45
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() How it will connect to the dashbar... ![]() ![]() Seat mount "frame" bars IN Seat mount's figured out (corollas suck for race seats...) Dash acquired and cut to fit, one bracket fabbed, need a few more Front Pin mounts done Rear pin mounts have the hole drilled, and thats it Dash bar located and welded. Steering column attachment fabricated. Half attached. Kind of. A pillar gussets fabricated and installed Fuel cell cage IN Trunk floor patched around cell cage I'm sure im missing something, but there is the gist of things Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
Post: #46
Forgot one....
06-11-2009, 09:03 PM
Post: #47
WOW, what a great job here.
Congrats ![]() |
06-23-2009, 10:56 AM
Post: #48
And a bit more progress...
My Dad has been feverishly working on the brake pedal while I've been working on all sorts of other stuff... He's gotten the balance bar adapter in and welded, and tacked the frame up for me to weld. I'll get some more pics of the assembly when its right prior to paint, and after. Here is the pedal, ready for paint and finishing, but i was checking clearance for the steering column. Everything was good! ![]() And the reinforcement plate for the firewall, well, at least part of it... I may be running a small tube to the strut tower depending on flex. ![]() Here is the bracket I fabbed for the steering column ![]() ![]() Its finally living in it's little home... ![]() I'll get some more pics soon. Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
06-23-2009, 10:59 AM
Post: #49
didierae86 Wrote:WOW, what a great job here. Thanks! Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
06-25-2009, 08:44 AM
Post: #50
Well, got the dead pedal fabbed and installed today.
![]() Dead pedal ![]() Inside... sprayed with weld thru primer to help keep rust down. I forgot to do this to the steering column bracket. Oops ![]() Tig welded top. Kinda tall welds... too much rod ![]() checkin out its home ![]() gotta check the angles out ![]() Its moved in! ![]() Solid foundation ![]() Strong attachment up top That's pretty much all I did today. I moved a bunch of stuff around so I can finish building the rotissorie to finish the underside of my car. Overkill? probably, but hey, the metal was free. Wow, I could have sworn I had an account here... I guess I'm the new guy ![]() |
AE86 N2 (big update) | 86Pilot | 110 | 148,183 |
09-06-2013 11:33 AM Last Post: Apsogos |
86er's Track rebuild N2.??? Finally an update page 8 | 86er | 191 | 277,657 |
Supercharged Hachiroku "update" | roadrunner | 20 | 26,508 |
06-02-2011 03:27 AM Last Post: kennedy8383 |
AE86 two door 1987. in restoration, in Iceland UPDATE | olithor | 12 | 22,699 |
08-08-2009 12:36 PM Last Post: rs1800 |
AE86... update 25/06.. car might be for sale | Eiwiss | 57 | 71,335 |
08-01-2009 03:16 AM Last Post: rymax86 |
