American Rally 86 UPDATE
04-02-2009, 09:10 PM
Post: #41
Yeah, I looked at yours and said, "Hey! I can do that!" lol
I had wanted to do it, but wasnt sure how to execute it. Then I saw your build, and liked how you made yours.
Wow, I could have sworn I had an account here... I guess I'm the new guy Sad
04-03-2009, 05:22 AM
Post: #42
hehehe, yours is much neater though Smile
just dont roll it like i did mine
Brake with the left hand, steer with the right foot...
04-03-2009, 07:18 AM
Post: #43
Yeah.... It'll happen eventually though... or I'm not going fast enough Wink
04-06-2009, 01:09 PM
Post: #44
Dude, are you going to throw the car from a cliff while you're in it?
That roll cage has more steel in it than the whole car chassis!
Although that's the safe way to go, I guess!
Smile
06-11-2009, 07:46 PM
Post: #45
[Image: AEU86 AE86 - American Rally 86 UPDATE]
How it will connect to the dashbar...
Seat mount "frame" bars IN
Seat mount's figured out (corollas suck for race seats...)
Dash acquired and cut to fit, one bracket fabbed, need a few more
Front Pin mounts done
Rear pin mounts have the hole drilled, and thats it
Dash bar located and welded.
Steering column attachment fabricated. Half attached. Kind of.
A pillar gussets fabricated and installed
Fuel cell cage IN
Trunk floor patched around cell cage
I'm sure im missing something, but there is the gist of things
Post: #46
Forgot one....
06-11-2009, 09:03 PM
Post: #47
WOW, what a great job here.
Congrats Thumbs up!
06-23-2009, 10:56 AM
Post: #48
And a bit more progress...
My Dad has been feverishly working on the brake pedal while I've been working on all sorts of other stuff... He's gotten the balance bar adapter in and welded, and tacked the frame up for me to weld. I'll get some more pics of the assembly when its right prior to paint, and after.
Here is the pedal, ready for paint and finishing, but i was checking clearance for the steering column. Everything was good!
And the reinforcement plate for the firewall, well, at least part of it... I may be running a small tube to the strut tower depending on flex.
Here is the bracket I fabbed for the steering column
Its finally living in it's little home... Big Grin
I'll get some more pics soon.
06-23-2009, 10:59 AM
Post: #49
didierae86 Wrote:WOW, what a great job here.
Congrats Thumbs up!
Thanks!
06-25-2009, 08:44 AM
Post: #50
Well, got the dead pedal fabbed and installed today.
Dead pedal
Inside... sprayed with weld thru primer to help keep rust down. I forgot to do this to the steering column bracket. Oops
Tig welded top. Kinda tall welds... too much rod
checkin out its home
gotta check the angles out
Its moved in!
Solid foundation
Strong attachment up top
That's pretty much all I did today. I moved a bunch of stuff around so I can finish building the rotissorie to finish the underside of my car. Overkill? probably, but hey, the metal was free.
  AE86 N2 (big update) 86Pilot 110 137,324 09-06-2013 11:33 AM
Last Post: Apsogos
  86er's Track rebuild N2.??? Finally an update page 8 86er 191 256,582 03-25-2012 10:05 AM
Last Post: bozu
  Supercharged Hachiroku "update" roadrunner 20 24,047 06-02-2011 03:27 AM
Last Post: kennedy8383
  AE86 two door 1987. in restoration, in Iceland UPDATE olithor 12 20,861 08-08-2009 12:36 PM
Last Post: rs1800
  AE86... update 25/06.. car might be for sale Eiwiss 57 65,225 08-01-2009 03:16 AM
Last Post: rymax86
