April fool joke by my car?
04-02-2006, 01:14 PM
I went out yesterday and the car revved to 2000rpm because it was cold. Driven 1 or 2 km's and i was standing in front of a crossing and it revved from 1500 rpm to 2500 rpm to 1500 rpm to 2500 rpm etc etc.
After 4 or 5 km's it was gone and revved just 1000rpm. Anyone familiar with this problem? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
04-02-2006, 01:28 PM
Vacuumlines
04-02-2006, 04:52 PM
More often it's the cooling system (too little coolant), or clogged water lines somewhere around the intake manifold. Also check if your TPS sensor is still okay...
04-03-2006, 12:02 PM
Mine does it too, but only from 1500 to 2000 rpm. And only a couple of times when its still cold.
04-03-2006, 07:28 PM
yep I had it again yesterday and today. Knudsen your right! its 500rpm difference... begins with 2000-2500 and when its getting hotter it goes from 1500-2000 and after that it's normal 800 :S
Ivan: TPS sensor = Temperature Sensor? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
04-03-2006, 07:42 PM
TPS = Throttle position sensor
1987 AE86 http://www.bilgalleri.dk/html/gal_visbil.asp?ID=41755 http://www.aeu86.org/forum/viewtopic.php?t=3255 ...FWD SUCKS!!... |
04-03-2006, 07:45 PM
thanks!
04-03-2006, 08:25 PM
Well, in my case i KNOW that it isnt the TPS sensor thats causing the problem. I can see the percentage of the TPS on the Apexi SAFC, and its allways @ 0% when the problem accours.
04-04-2006, 07:20 AM
Like I said, most of the time it's the cooling system that's the cause of this. But a faulty/out of adjustment TPS is said to have the same effect on idle speeds.
04-04-2006, 08:21 PM
Ivan you're right! My car is slowly losing coolant. Don't know where it leaks exactly but I will take a close look this weekend.
Thanks for the info Ivan! 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
