Aram's 3SGE Beams Levin Coupe
08-20-2013, 07:58 AM
Post: #621
the oilpan is quite LOW? is there any room to go up or need totan new steel part to get it little higher?
08-20-2013, 12:44 PM
Post: #622
Thanks Dave!
Yes the oilpan is very low, 7cm.
First on the list is making some protection for it. :-)
08-20-2013, 05:31 PM
Post: #623
nice work Thumbs up!
08-20-2013, 05:59 PM
Post: #624
Aram Wrote:Thanks Dave!
I must look what i can do whit my self.. best would be make the lower steel-pan my self. WHIT 3-4cm lower but lot wider.. But i must look up to it.. WAY to low be without protection
08-20-2013, 08:20 PM
Post: #625
Thumbs up!
08-20-2013, 08:25 PM
Post: #626
[Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]
08-20-2013, 09:45 PM
Post: #627
I like what Fer Monti has done: https://www.facebook.com/media/set/?set=...514&type=3
That will probably be a good solution.
08-21-2013, 06:45 AM
Post: #628
yep. i have looked same pictures. Lot better to get few cm from stock. Even that much it must help lot. Its sit so low whitout
08-22-2013, 08:10 PM
Post: #629
very welcome !
with the oil pan i'd assume you should be able to get bigger motor mounts or make some to raise it a bit to help or no?
08-22-2013, 08:18 PM
Post: #630
i think there is not much room whit Stock hood and beams "valve cover"
  ae86 racecar with beams engine bakonick 148 163,423 04-23-2024 10:06 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 88,446 05-07-2019 09:35 PM
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,790 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 159,752 03-28-2018 12:35 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 604,493 06-27-2017 12:21 PM
Last Post: DJexor
User(s) browsing this thread: 32 Guest(s)
