Aram's 3SGE Beams Levin Coupe
03-16-2010, 05:52 PM
Post: #71
jesus aram! im surprised you drove your daily around like that!
Brake with the left hand, steer with the right foot... |
03-16-2010, 06:35 PM
Post: #72
Livin' on the edge!!!!!
03-17-2010, 12:14 AM
Post: #73
![]() btw... does anybody know what these cars use to get the sparks? they have some kind of metal slider underneath... |
03-27-2010, 06:29 PM
Post: #74
So I fixed the shock problem, I swapped it with one from the project car.
![]() And today we finaly turned the car on it's side, now the beams under the trunk can be fixed. After this it's going on the grill. ![]() Should have update pics later this week!! ![]() ![]() ![]() ![]() |
03-27-2010, 07:29 PM
Post: #75
I think that fender flare should be turned a little bit rear...
You should measure where is a centerpoint on the flare and a rear arch, then put it on right place. "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
04-30-2010, 02:52 PM
Post: #76
Yes, good point, this one is coming off, and I will be there when we fix the new one.
This time we will have the new wheels too! Just got them on Teusday, tires are here the 6th. ![]() ![]() ![]() ![]() Check the difference in white between the wheel and the car hahaha. |
06-12-2010, 08:51 PM
Post: #77
Alright, a small update.
Wheels on the car: ![]() ![]() ![]() Also received my digidash. ![]() ![]() ![]() Then we started on the rear arches. I was not satisfied with first attempt so I was present this time. So now they are on to my taste. ![]() The Ford fenders are about 1.5 cm wider then standard I think. The wheel under the car in the next pic have a 20mm spacer. They are about 10mm too wide so I need 10mm spacers. I think it will look great actually. ![]() First steps: ![]() ![]() ![]() And welded on: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
06-13-2010, 10:12 AM
Post: #78
Well done guys, brilliant work, Keeping the ae86 alive indeed
06-13-2010, 10:56 AM
Post: #79
Thanks m8, it's nice to create something alive again from a wreck indeed.
06-13-2010, 05:45 PM
Post: #80
nice work you have done so far,that was much rust you have found..
what size/brand of wheels is that ![]() daily driver avensis 2.0 d4d and Yaris 1.0 weekend driver 1985 AE86 |
ae86 racecar with beams engine | bakonick | 148 | 156,773 |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 84,115 |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 13,755 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 153,796 |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 588,512 |
