Aram's 3SGE Beams Levin Coupe
08-12-2010, 01:02 AM
Post: #141
hey aram,
Ziet er allemaal super uit man! Ga zo door! Hoeveel was je kwijt voor dat elektrocoaten? en waar kan je dat doen? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
08-12-2010, 06:13 PM
Post: #142
I had the drawing put onto cellophane or whatever you call it in English, but it's see thru.
![]() To check if my drawing would cover the holes on the back of the head properly. And it's not to bad actually, only adjustment I have to make is to place the o-ring a bit more to the outside. ![]() ![]() Here you see the reason for the change, the top of the hole sticks out a bit more than I anticipated, 1mm more offset to the outside with the 0-ring will fix that: ![]() And this one is fine by me: ![]() The engine I bought was made ready for the autocross, so they already had taken off the dizzy and put this in it's place: ![]() ![]() The inner part looks like something that was cut of the original part that was on the dizzy, can anyone confirm this? A look inside the hole: ![]() Does this look normal or are there parts missing? I will take off the valve covers later so I can take better pics. |
08-12-2010, 06:49 PM
Post: #143
jow ik hoop dat je een goede koop gedaan hebt met die motor......
ik heb ook een keer een autocross motor gekocht namelijk,en die was al op ![]() drift ae86:308bhp/435nmEDIT:384pk/498nm!!!!>now DEATH))) |
08-12-2010, 07:03 PM
Post: #144
Ja, dat is de gok.
![]() Als ie niet goed is zal ik toch wat anders moeten gaan halen, we zien wel. ![]() |
08-13-2010, 12:02 AM
Post: #145
Aram Wrote:Anyway, this is what I came up with: Very neat solution ![]() ![]() ![]() RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式 |
08-14-2010, 08:22 PM
Post: #146
I did this with Pro-E mate.
I can send you the drawing if you want, no problem. ![]() |
08-15-2010, 07:12 PM
Post: #147
As said before, my engine came with this block off for the original dizzy placement.
![]() ![]() ![]() That looks like crap off course, so I made another drawing: ![]() ![]() ![]() Only thing is, I don't know if I need this space for a camshaft position sensor. For the aftermarket ECU I mean. I know it is possible to put an EDIS sensor on the crank pulley or use this position for something similar. Anyone knows what the possibilties are for this sensor? |
08-15-2010, 09:45 PM
Post: #148
GZE's have a sensor in that position, dont know if it'll fit a 20v though...
08-24-2010, 07:19 PM
Post: #149
Welded something the rear axle, it's ready for powdercoating now:
![]() ![]() And had my 20V alternator converted to 16V connector, and a general refurbish: ![]() ![]() |
08-24-2010, 09:03 PM
Post: #150
Aram Wrote:As said before, my engine came with this block off for the original dizzy placement.That was made from original or some other engine dizzy (4A-F?). 4A-F have that kind of cam end and dizzy comes straigt to it. ![]() "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
ae86 racecar with beams engine | bakonick | 148 | 156,734 |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 84,084 |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 13,689 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 153,697 |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 588,145 |
