Aram's 3SGE Beams Levin Coupe
10-10-2011, 09:07 PM
Post: #341
Some ITBs would be nice on this one Hurray!
10-10-2011, 09:39 PM
Post: #342
uuh is this just porn without sex?
looks awsome
regarding the bearing; do you have the sizes? there are lots off industrial shops who sell bearings.
try one off those?
Gtsi-R
"Trust me, I was an engineer"
10-15-2011, 10:19 AM
Post: #343
Thanks Zenki. Smile
@KD2229,
I will be looking into the radiator soon, when I find something I will be sure to let you know. Thumbs up!
@Bozu,
When will you get back, and will you build it in Holland or Aus?
@Fii,
Itb's would be lovely indeed, but a bit out of reach atm. Wink
@Gtsi-R,
Thanks for the kind words.
I already found a bearing, not cheap but it was here fast. Wink
Picked up my rear axle yesterday, will take pics later today.
Greets,
10-15-2011, 10:59 AM
Post: #344
what rear axle setup are you going to use?
I might jump the Beams bandwagon too and hence even more interested in your build.
10-15-2011, 11:39 AM
Post: #345
For now I use the stronger standard axle with the thicker splines.
Maybe later I will go for a Celica or Hyundai van item.
I am not going to use it for 100% and if you don't do clutch dumps it will be strong enough.
But I do think it is important to have it set up right, good shimming etc.
10-15-2011, 11:43 AM
Post: #346
I'll be back in Holland on the 20th this month but my car isn't coming untill the end of november. It's now here in a container waiting to be loaded on the ship that's going to take it to Holland.
I don't know when and where I'm going to do the build so I'll stick with my 4agte for now and save money and do the research for the beams turbo conversion that I want to.
10-15-2011, 11:46 AM
Post: #347
Aram Wrote:For now I use the stronger standard axle with the thicker splines.
sounds good - an alternative I thought about is the weir axle kit but it's not a cheap option as you'd need to get the diff from them as well...
I know most people are going for an aftermarket ECU but I wondered if you found any info one someone who tried to keep the OEM stuff, I haven't found anything so far...
10-17-2011, 10:44 PM
Post: #348
I am keeping the oem ecu actually, but someone else is doing the wiring.
It will be the Altezza engine loom, the rest is ae86.
What is it you want know?
10-17-2011, 10:48 PM
Post: #349
Pics of the rear axle, going under the car this week I hope.
[Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]
New wheel bearings, new solid pinion spacer, mechanical seal, gaskets and paint of course. Smile
10-17-2011, 11:00 PM
Post: #350
looking nice Smile
had word with my seller of the engine and I'll be getting the complete Altezza loom so should be a breeze to fit
  ae86 racecar with beams engine bakonick 148 168,030 04-23-2024 10:06 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 91,497 05-07-2019 09:35 PM
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 15,540 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 163,637 03-28-2018 12:35 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 618,394 06-27-2017 12:21 PM
Last Post: DJexor
User(s) browsing this thread: 36 Guest(s)
